is there any way of seting windows 7 to stop the hard disc from sleeping until the drive is needed. it bugs me and when im listning to internet radio on my HTPC the audio stops for a second untill the drive starts up again. any help..??
windows 7 harddisc idle
1. Open Power Options to change the advanced power settings, and expand Sleep and Hibernate after. (see screenshot below)2. Under Hibernate after, set the Setting (Minutes) to Never. (see screenshot above)
3. Under Allow hybrid sleep, set Setting to Off. (see screenshot below step 4)
4. Click on OK. (see screenshot below step 4)'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
-Bishop Desmond Tutu -
power saver.....change power settings'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
-Bishop Desmond TutuComment
yeah, that should do the job for you !'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
