external harddrive psu
  • binary
    • Mar 2009
    • 121
    Hi Lads, Has anyone got a Seagate 500gig external harddrive if so can you advise what the PSU DC voltage is guessing either 5 or 12 volt
  • Dreamer
    • 2020
    There are a couple different models for seagate 500gb external drives. which model is it you have?
    The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
    • binary
      • Mar 2009
      • 121
      Thanks for the quick response although th HD has no model no. on it checking their site it looks to be Model ST305004EXA101-RK 500 GB one mistake i made in my request 6 volt not 5 volt if i am correct. so the request is which voltage 6v or 12 v
      • Dreamer
        • 2020
        that model would mean it is a a seagate expansion model and would therefore have a 12v power adapter with interchangeable pins depending on the country you are using it in
        I have sent you a PM with some info from seagate
        • binary
          • Mar 2009
          • 121
          external harddrive 12volt psu
          Lancashire, UK. Found a 12volt power supply and checked it out works perfick. Many thanks for your time and attention. Cheers
