Abobe CS 5 Serial Problems
  • opsmonkey
    • 5379
    Anyone using Adobe CS5..??
    Mine has been flawless since release but today it has come up with "serial has expired"..
    Now every serial generated via the keygen is coming up not valid..??
  • allycoops
    • Feb 2008
    • 1075
    Untested OPS
    So check crack etc 1st Mate
    CRACK FOR INVALID SERIAL NUMBER (32-bit) PROBLEM
    Note: This Crack Is Only For 32-Bit Windows
    Instruction: Go to your Photoshop Installation Directory (Most Probably " C:\Program Files\Adobe\Adobe Photoshop CS5 " and Replace The amtlib.dll with the new one given in the crack
    Download Crack (32-bit)
    http://www.6ybh-upload.com/8s6zmn7s894z/PS5.CRACK_32.rar
    CRACK FOR INVALID SERIAL NUMBER (64-bit) PROBLEM
    Note: This Crack Is Only For 64-Bit Windows
    INSTRUCTIONS:
    For 64 bit versions of Windows such as Win 7 x64 two copies of amtlib.dll must be replaced. (backup your original amtlib.dll)
    First the 32-bit crack (download from above) amtlib.dll must be copied to "X:\Program Files (x86)\Adobe\Adobe Photoshop CS5\" overwriting the file that is there. (Important: Please again note that replace x86 amtlib.dll with 32-bit crack, NOT 64-bit).
    and the patched 64-bit crack (download from below) amtlib.dll should be copied to "X:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\" (Important: Please again note that replace x64 amtlib.dll with 64-bit crack, NOT 32-bit).
    Download Crack (64-bit)
    http://www.6ybh-upload.com/hlq7hpm8ixg0/ADBE_CRACK64.rar.html
    Let the others come after us, We welcome the chase
    • opsmonkey
      • 5379
      cheers mate.. the 64B link looks to have been taken down
      • allycoops
        • Feb 2008
        • 1075
        My Fault Bud
        here ya go, make sure you get the underscore at the end of the link when you copy and paste
        http://www.6ybh-upload.com/hlq7hpm8ixg0/ADBE_CRACK64.rar.html_
        • opsmonkey
          • 5379
          cheers mate... came up with a 404 error.. hopefully a fix will be on the software site i frequent soon
          • cunny
            • 4915
            My CS5 Working sweet
            • allycoops
              • Feb 2008
              • 1075
              here you go OPS
              I've downloaded the 64 and attached
              • opsmonkey
                • 5379
                thanks ever so much mate.. i'm getting an error with the 32B one as well.. when i get the link for my IP it shows a 404 error too..!
                can i be cheeky and ask you to zip up the 32B amtlib.dll
                • cunny
                  • 4915
                  Let me know how u get on ops..will see what i can dig out...but i am running th x86 (32bit) versions
                  • allycoops
                    • Feb 2008
                    • 1075
                    here you go OPs 32bit
                    • opsmonkey
                      • 5379
                      get in.. cheers for your help mate.. now working perfectly again..
                      • cunny
                        • 4915
                        Was just downloading the full versions for the work arounds ....need to get a copy anyway
                        • allycoops
                          • Feb 2008
                          • 1075
                          Glad its sorted OPS
                          Cheers Bud
                          • opsmonkey
                            • 5379
                            I've saved the files with the ISO's I've got..
                            The disable_activation.cmd that I had must have been worked around..
                            • cunny
                              • 4915
                              There's a key gen and a work around to aviod the dial home, not too sure what 1 u edit but there are 2 ways of working around it, will post .nfo when its downloaded, just for future reference
