incompatible with win7
  • reddevil157
    • 1427
    Took a 2.5 hdd from an old lappy, got an external enclosure, worked great on an XP lappy that has now gone to lappy heaven. Hdd is only compatible with XP, do I need another comp with XP or is there anything I can do to get it to work with win7. Not too technical please .
  • dasteph
    • 1293
    are you sure the hd has not gone to heaven as you should be able to access the drive with any o/s, recheck all your connections in the enclosure including power supply.
    • racin-snake
      • Jun 2009
      • 2285
      maybe the hd is ide
      i think win 7 may only be comfy with a sata drive ?
      not as an expert but just a passing thought
      Today is the Tomorrow you worried about yesterday ......Was it worth it ?
      • dasteph
        • 1293
        Originally posted by racin-snake
        maybe the hd is ide
        its in an enclosure so it would be usb to to his present pc, i have put a ide hd in a pc that runs 7 with xp loaded so files could be saved before a format of the drive without a problem, my present pc uses 7 installed on a ide drive.
        • reddevil157
          • 1427
          Thank's for the replies guy's, Racin, it is IDE , Dasteph, tried it with another USB and it's working fine on my Win7, thank's again.
          Red.
          • lexxspam
            • Mar 2010
            • 15
            on windows 7 go control panel administrative tools in list click on disk mangememnt from here your see what drives are plug into the computer an in what format (do not know what win7 your on ) could be will only read in ntfs may need to format drive to that for it too work
            • DW190
              Win 7 also needs a minimum of 1gb ram
              • reddevil157
                • 1427
                Got it working guy's thanks.
                Red.
