looking for help with vpn
  • billy2
    • 1381
    hi guys looking for some help please can anyone tell me how to get hotfiles to work with vpn ??? and IDM everytime i use a hf link with vpn in wont work when i trun of vpn it will work
    cheers
  • smokin
    • 255
    what country is the vpn server based in...works for me but I have a choice of 4 different country IPs to select from
    Technomate-Dreambox-Spiderbox
    • billy2
      • 1381
      vpn uk i think it has to do with the proxy setting
      • smokin
        • 255
        proxy is NOT a vpn account, but do believe that fileshare or filesonic will not work in the UK,( can't remember off hand) unless you use a IP from another country, like with a vpn
        • hannson
          • Dec 2010
          • 4
          hi. if you are using a VPN to your office... and your office proxy blocks the "fileshare or filesonic" sites, you won't be able to access it.
          is there a reason why you must use VPN?
          • billy2
            • 1381
            thanks guys all working now
            • smokin
              • 255
              I guess it depends if the office Admin is any good...if you connect to a vpn account, then the trail stops, then you should be able to connect to your fav file download site and the office Admin will not know the difference. From his screen you just go to some site, which will be non UK in your case, which to him will be just an IP address, so unless he is savy in on THIS site ip...it should be np.
              • Charjy
                How to set up a vpn server
                Hi,
                Can someone describe the steps how to set up a vpn 'server' from my home, so that I can access my files from outside?
                • smokin
                  • 255
                  Really a different question from just plain vpn use , which to me is used to protect yourself drom being "snooped" on by big brother....
                  You may want to redefine your question..
