How long for a repair of xp
  • mickydibble
    • 2166
    Just doing a repair of xp instead of a format,how long douse this take thought it maybe not that long been on like 50 mins---the hard drive is 160gb does that make a difference,does it have to check the all drive there was/is quite a lot on it it's pretty much full
  • mickydibble
    • 2166
    It's ok chaps apparently it can take several hours! And will restart when finished
    • mickydibble
      • 2166
      It's bee on all night and left it running this morning does that sound right ? Confused I know it's a big hard drive but for ~~~~s sake
      • cunny
        • 4915
        In recovery console with chkdsk /r to check the drive..
        I never use this option, always a clean instal of any operating system
        • mickydibble
          • 2166
          Was going to do a lean install but thought would try that option for a change wish I had not , anyway when I get home if it still doing that then I'll sack it off and do a fresh install
          If it's still running though will it be safe to just switch off??? Any ideas guys?
          • mickydibble
            • 2166
            Just got home and its still,still,still loading!!! Surely can't take that long??20hrs
            • roryson
              • Mar 2009
              • 694
              Don't know the reason why your doing a repair of windows mate. I put a clean install every now and then to keep it running nice. I use norton save and restore to create a image of a clean install, and use that instead of reinstall xp all the time. Better than install all your software again and again...
              • cunny
                • 4915
                No there is something a miss m8. ~~~~ it off. Do a clean instal, if everythin is backed up wipe the drive, if not, instal, backup then wipe the drive
                • Dallin
                  • Feb 2011
                  You can make a backup of your data to any External hard drive then install a fresh copy of operating system...
                  While it normally takes about 45-50 minutes, either you re-install an operating system or repair...
                  Chandler Homes for Sale
                  • jetdede
                    • Nov 2010
                    • 410
                    repair win xp depend on your HD size, specification of your computer...approximately 15 minutes for latest spesification (example if you use DDR3 SDRAM)
                    DK is The Most Valuable Site my friend
                    Don't forget to do it
                    right place to share each other, not to
                    Don't do it when you sleep, will make big cost
