hi guys i have a nero dsk image that i want to test before i burn it is there any way i can do this ?
howto unzip a nero disk image
Tags: None
Is it a pc iso or another iso for a different system?... if its a pc iso then you could mount it in a virtual drive to see how it will work when burnt to a disk.. should be one in nero.
Start the virtual drive and you should see it as another cd drive in "My Computer" screen... then mount the image to the drive. If it doesn't autorun then go to my computer and click on the drive and look for a setup exe to start whatever is on the iso -
same cause on me....
i find ultra ISO....install
then i extract it to a folder...that's all...is it easy friend...just try it.DK is The Most Valuable Site my friend
Don't forget to do it
right place to share each other, not to
Don't do it when you sleep, will make big cost
