HELP LG 42" and phillips hts3520 surround problem.
  • tony1458
    • Jul 2010
    • 13
    Just purchased a new tv today, trouble is my surround sound wont work with it. my surround doesnt have optical output like the tv. the only way i can get it to work is pluggin red,white and yellow aux lead straight into my sky box then back into ma dvd player. but then wen i want to watch a dvd have to unplug everything and its quite annoyin, i thought id be able to just plug the aux leads directly from ma dvd surround player into the tv and it would just play everythin that was on ma tv but it doesnt. Dont know if need change any settings or anything. tv model is 42le4500. Any help would be much appreciated.
  • smithie46
    • Aug 2009
    • 72
    does your surround have optical input if so its optical out from tv to surround
    • tony1458
      • Jul 2010
      • 13
      it doesnt have an optical output on ma surround pal but the tv does :-(. Any suggestions pal?
      • tony1458
        • Jul 2010
        • 13
        if i buy a scart that has an optical box attached to the scart plug that into my dvd player then put optical from tv to that, that should work shouldnt it? just sin them on ebay
        • cactikid
          • 12017
          no hdmi sockets?? found this
          Philips Connectivity Guide
          • smithie46
            • Aug 2009
            • 72
            sound
            what make of sorround is it
            • tony1458
              • Jul 2010
              • 13
              surround sound is phillips hts3520 mate
              • tony1458
                • Jul 2010
                • 13
                and yes it does have hdmi sockets just cant get to work gotta b sumat and nowt
                • cactikid
                  • 12017
                  hdmi is not set to on,you may need to activate it in settings so it knows what to use,some high end receivers give the option of hdmi,scart etc and need to be assigned.
                  on tv optical out to INPUT optical in on surround system.
                  • tony1458
                    • Jul 2010
                    • 13
                    how do i turn that on? and will it work then?
