Too strong a signal
  • deuteronomy
    Too strong a signal
    My parents just paid for a freeview (log periodic) aerial installation for their samsung freeview tv and now they get freeview the tv looses the epg with bits missing and it locks up in the epg a lot (le26r5 tv)
    the guy who installed it said the signal in their area was too strong with the new aerial now so put a 9db attenuator on the line and says the tuner was damaged from the constant weak singal from the old aerial all these years, is this true, i thought a strong signal was a good thing.
  • aftermath
    • 4345
    the engineer is correct, a strong signal will need an attenuator to decrease the signal, you say he tried a 9db, try a 3db see if that helps. Or if you got one of those internal digital aerials try that .
    you could also try a signal booster, one that you can adjust, so you can decrease the signal.
