A laptop needs to be switched to TV out before it will work.
If it's a PC then make sure you have the correct input chanel selected. Sound is shared over a few inputs so you have to make sure you get the right one for the video feed.
Canker "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
- The Baby Eating Bishop of Bath & Wells[COLOR=Green]
If it is an LCD tv its a good chance the inverter (power supply) for the backlight is bad, if the backlight is lit and there is no picture it couuld be the t-con board (board drives the lcd panel)
