Hi, i have a sanyo CE26LD81-B Tv.
When you first turn it on the picture is distorted with linnes running horizontal across the screen and jumping about.
You can see some of the picture the other is white lines, black lines or blue lines some are thick widthed and some thin.
Once the tv is warm after about 10min they all disapear and the full picture comes on.
Has anyone any ideas as to what could be wrong please??
I am quite technically minded so am not scared to open it up and do what needs to be done to get it fixed just need pointing in the right direction as to what part/s i need to be assessin.
I have spent 2 nights googling for as much info as i can with no joy at the mo.
Cheers.
Cheers.
Do they look something like this, then clean the lvds cable, it looks like this
usually it is the black end that goes to the T-con board that causes the problem, Or it could be the lcd panel itself causing the problem.
