WD Passport problem
  • johnny7511
    • Oct 2013
    • 17
    WD Passport problem
    Hi guys went to plug the wd passport in to wd live box all i am getiing is the blue lights flashing can here the drive going just nothing happening keeps on flashing when i plug it into the computer it cant find in the drive sometimes the computer freezes all all my photos are on it eveything was working ok at the weekend.
    cheers for your help
  • ontherack
    • Apr 2011
    • 1080
    if plugging into usb, is usb ok, is drive recognised by computer..try....this..https://technet.microsoft.com/en-us/library/cc732026.aspx?tduid=(9ec87d58f260d1abe39833c780c38 ef9)(256380)(2459594)(TnL5HPStwNw-0MCGbXOiN1GIgjS_NdP.Gw)()
    • DOUGALMCD
      • May 2011
      • 3229
      Have you tried a different usb cable with it? I have one and it was problematic until I got a new cable. hth
      • mike255
        • Dec 2017
        • 57
        not going to be your usb cable as they are not standard.
        this is a design flaw with the units that can fail out of the blue wont give you a warning it failing
        it just does.
        it might pickup in hardware but not seen in windows and the gb amount will be 0
        going to be a expensive data recovery job not that easy and nope no DIY can do this.
        • arky4
          • Mar 2009
          • 224
          it just does.
          same thing happened to me tried everything lost a lot of stuff if does not show up in my computer its goosed the passport is too
          tempreamental mines never moved from the top of my pc still zero data could not recover anything
          tiger4
