Apologies if this is in the wrong section but coudln't find a TV fault section
I have a Bush 50211F 50 inch TV
It has just turned 4 years old and has been my primary TV for Sky and 19.2
I noticed a few weeks ago it got stuck in standby but by turning it off and on again at the plug it worked again.
However after getting home from work last night the TV would not go out of standby mode.
I turned it off and on again at the plug multiple times it still was stuck in stand by. Tried from the remote and the buttons on the tv itself.
I then googled the symptoms but the only fix I could find was hold the stand by button for 30 seconds unplug the tv whilst still holding the button then plug it back in and it was meant to reset it or something but that did not work either.
Somebody else mentioned it could be the power supply but would the power supply be faulty if the TV is still getting power to go into standby? I also opened the TV last night and theres no bulging capicitors to be seen.
The TV is just showing a solid red light theres no blinking codes or anything.
Does anybody have any pointers on where would be a good place to look next to get this TV fixed?
Any help would be appreciated
Cheers
Cheers
