I know i've seen it before but how do you see the Windows partions with Ubuntu8.01 i think it used to look something like hda 1
Can't see Windows partion
need to mount the hdd point as something like /media/windows
add thisCode:sudo mkdir /media/windows sudo cp /etc/fstab /etc/fstab_backup gksudo gedit /etc/fstab
save that file.Code:/dev/hda1 /media/windows ntfs nls=utf8,umask=0222 0 0
reload fstab
Code:sudo mount -a
boom! -
Lol i just did the exact samething with thisAnyhow now have thisCode:tar czvf /hdd/600.tar.gz /etc/enigma /usr/keys /usr/scce /usr/lib/tuxbox/plugins/
ThanksCode:laptop:~$ sudo mount -a ntfs-3g: Failed to access volume '/dev/hda1': No such file or directory Please type '/sbin/mount.ntfs --help' for more information. laptop:~$ /sbin/mount.ntfs --help ntfs-3g 1.2216 external FUSE 27 - Third Generation NTFS Driver Copyright (C) 2006-2008 Szabolcs Szakacsits Copyright (C) 2005-2007 Yura Pakhuchiy Usage: ntfs-3g <device|image_file> <mount_point> [-o option[,...]] Options: ro (read-only mount), force, remove_hiberfile, locale=, uid=, gid=, umask=, fmask=, dmask=, streams_interface=, syncio. Please see the details in the manual. Example: ntfs-3g /dev/sda1 /mnt/win -o force Ntfs-3g news, support and information: http://ntfs-3g.org
DanComment
The problem is being told to you ^^,,, problem is it cannot access /dev/hda1.... Is this the partition you have windows installed?... use Gparted to look at the differnet partition names and numbers and edit to match the partition your windows is on... ( thats if you made sure you didnt OVERWRITE it with ubuntu and done the install manually )boom!Comment
Hi M8 link not workingOriginally posted by [email protected]
but thanks any way at least i know where it's hidingComment
