Explain this line of code please
  • despdan
    • 544
    Now I know the first bit goto this address & get filename it's the -O filename 2> /dev/null bit I don't know what exactly it does.
    wget -q http://webaddress/filename -O  filename 2> /dev/null
  • red devil
    • Oct 2008
    • 690
    have a look here Of Zeros and Nulls
    • Mjolinor
      V.I.P. VIC
      • 1093
      the "-O" should be "-o" it just defines the output file name. And by piping the output to NULL you are telling it to be quiet about it, you won't see any screen output, it throws it away
      • despdan
        • 544
        Thanks red just what i was looking for
        I was following another tut but skipped over little things like -f -0 -s & you just know there the things that need explaining
        • beady
          • 27
          Not really true. "-o" defines where the logfile is written to, while "-O" specifies a file to save to. So the original command save the file "http://webaddress/filename" to the local file "filename", and discards any output generated from the "wget" program itself (which would usually get sent to stderr, which will default to the terminal, as described in the link posted by red devil). You can get pretty much the same effect by using
          wget http://webaddress/filename -O filename -o /dev/null
          in which you have specified that logging goes to the /dev/null device (i.e. is thrown away).
          Overall though, the purpose of the command is to download a file from t'internet silently, without any text being sent to a terminal.
          edit: Actually, it's already "quiet" because of the "-q" option, so if successful, nothing will be displayed on the terminal. However, in the event of an error, like the url being invalid or a more serious error, the "2 > /dev/null" makes sure nothing is displayed.
          • Mjolinor
            V.I.P. VIC
            • 1093
            Yup, my bad. Apologies.
