why does my ip keep changing?
  • barrowmanandrew
    • 3427
    a little help needed here please.
    i have been streaming movies from my pc to wii recently over my wireless router but great success.
    the last few days something strange has been happening.
    my pc ip was always 192.168.1.2 but recently it has started changing.....
    it seems to change from 192.168.1.1 through to 192.168.1.4.
    this ~~~~s up up my network sharing...
    anybody any idea whats going on??????
    all i have on my router is a
    1. pc
    2. lappy
    3. wii
    4 kv780
    any help appreciated.
    p.s.
    im a total novice with networking , so please be gentle...
  • opsmonkey
    • 5379
    If you go into your router configuration you can give dedicated addresses to your items making them static IPs over your LAN
    • barrowmanandrew
      • 3427
      you wouldn't happen to have a dummies guide on it, would ya... .
      its strange how it stayed the same for so long then started changing
      edit....
      i think ive got it,
      went into lan settings and set up address reservations....
      seems to be ok now....
      thanks for your help....
      • oneman
        • 307
        Also make sure your wifi is not getting hacked.
        Most DHCP servers (which your router most likely is) will remember a MAC address and keep giving it the same IP address until the address range has run out at which point it starts recycling addresses which have not been renewed.
        • barrowmanandrew
          • 3427
          now you've got me worried....
          if it is being hacked, will it show up in connected devices?
          • oneman
            • 307
            Yes it should do if they still have a connection.
            Another alternative is that somebody manually configured their IP to your old address and DHCP checked if it was free before using it.
            • coffepls
              you must disable dhcp .
              go in start . run . type cmd .
              type ipconfig/all . save all the info there . ip , gateway , subnet dns .
              than go
              Control Panel\Network and Internet\Network Connections open local area connection with right mouse click . select tcp ip v4 . and click properties . than chose . enter this IP manualy and dns manualy . and enter your ip like you want .
              do this for every device . than disable dhcp on your router .
              • oneman
                • 307
                than go
                Why ?? putting in dhcp reservations will ensure that all devices keep getting the same addresses they currently do.
                • barrowmanandrew
                  • 3427
                  than go
                  a little bit out of my comfort zone there
                  thanks anyway, seems fine now with the reservation set up......
