VOIP
  • thered
    • Aug 2008
    • 4915
    VOIP
    Noob on this subject have never given it any thought im wondering what i need to get started
    a few pointers i would like to know
    what phone as basic and as cheap as i can get or can i use adaptor for phone i have already
    i would like to have a fe seperate phone numbers how do i do this ?
    who is cheapest and i would like local area numbers if possible
    thank you and good afternoon
  • TheCoder
    • Jun 2011
    • 693
    The GrandStream IP phones are pretty good. Got myself a 200 series one (two SIP providers at once) off ebay for ?10. Something like - Grandstream GXP-2000 SIP VoIP Phone 4-lines | eBay
    Phone basically just plugs into your standard router. Setup is fairly easy using a standard web browser on your PC. A number of providers will even auto generate the configs for your particular phone.
    For service provider I tend to use a couple. Incoming calls are mostly Sipgate as you can get a regional number for free and they are pretty reliable (important for incoming calls). There outgoing call aren't the cheapest though so I tend to use one of the budget suppliers for most outgoing (voipcheap) calls falling back to Sipgate if the cheaper route fails.
    • thered
      • Aug 2008
      • 4915
      thanks my router is upstairs but i have my dreambox connected by ethernet cable downstairs
      would i be able to use this to work both phone and dreambox
      3 PORT RJ45 LAN ETHERNET NETWORK CONNECTOR SPLITTER | eBay
      as too run another wire would be a pain and i have been the wireless route before
      or does phone need its own singular lead from the router
      ideally i want 2 phones one in front room as a house phone
      the other with more than one line can be upstairs near router anyway
      • TheCoder
        • Jun 2011
        • 693
        Not sure of that as cant quite fathom what its actually for !
        A simple hub or switch would do the job though. Something like -
        Edimax mini 5 Port 10/100Mbps Switch - Misco.co.uk
        One line out of your router down to the switch and you then have 4 extension ethernet lines to play with.
        • learing1
          • Mar 2010
          • 100
          forward port 5060 for SIP to target device.
          check Tribbox CE / PBX in a flash / Elastix.
          with that you can do all the fancy things providers offer.
          you can have different trunkss / routes for making calls to save also if you want to go very in depth.
          i recommend for an ATA linksys PAP2-NA there is many for $25 or so on ebay shipped and can shipped.
          It is a 2-line DEVICE.
          • thered
            • Aug 2008
            • 4915
            turns one ethernet lead into 2 so i can put 1 in phone and 1 in box
            if i get a switch like that one doesnt it mean i have too manually use each switch as required or does it do it automatically open them as required ?
            • TheCoder
              • Jun 2011
              • 693
              Yes, but I cant see how it does it. Generally you cant just take a single ethernet connection to two devices. You need the functionality of a hub/switch.
              Its all totally unsupervised and automatic .
              • thered
                • Aug 2008
                • 4915
                ok that is great
                now thinking about this i may keep my landline phone downstairs can i use this too convert it to voip and use it as a house phone
                Skype to Phone VoIP Landline ATA PSTN Gateway Adapter | eBay
                i will then get another phone for my pc/office area that i can have numerous different local numbers for
                would that be ok ?
                • thered
                  • Aug 2008
                  • 4915
                  ok that is great
                  would that be ok ?
                  Bump to topic
                  • TheCoder
                    • Jun 2011
                    • 693
                    Not sure that would be the thing you require !It seems to be a USB adaptor that allows you to connect an ordinary phone to your PC and then use that to make Skype calls. I dont think it will operate without the presence of the PC and probably only operates for the Skype service, not standard SIP.I'd guess what you really want is a SIP adapter but these often tend to be around the same price as a SIP phone so may hold no advantage for you.Something like - Linksys PAP2 ATA - VOIP - Comes with free cordlessphone | eBay be careful - a good number of those devices are provider locked so make sure the description specifies its unlocked to all providers as the above one does.
                    Last edited by TheCoder; 5 August, 2011, 01:16. Reason: strange formatting problem
                    • TheCoder
                      • Jun 2011
                      • 693
                      Dunno why but text formatting has gone to pot - I cant add new lines or anything ?????
