how to hack wep key
  • Time2Play
    • Apr 2009
    • 309
    #31
    him using russix it will boot perfect on my pc which runs on xp but when i put it on my laptop which runs on vists it will go as far as the clover and welcome to slax and go no further any help
    SAY THANKS OR JOK WILL TAKE PICTURES OF YOU IN YOUR SLEEP
    • Tommy123Tommy
      • Sep 2009
      • 57
      #32
      my cd seems to work fime on vista, 7 & xp, the only problem im having is that it is not detecting any of my wireless cards and i have tried 3 , do you need a certain kind of network card or something ?
      Also anyone got a new link to the instructions
      • ^^TommyTee
        • 424
        #33
        take a look at backtrack
        install vmware workstation and run it side by side with windows
        lots of stuff on backtrack and education in itself
        part of the process too cracking a wep key is by bruteforce ie.. too attack with a dictonary of words
        and also packet injection and you wanna get a high power wireless card
        the best by far is ALFA 500Mw card has full backtrack 4 compliance
        and get a good wifi aerial a Yagi 18Dbi is a good pointer
        check the new 1000Mw card
        you can crack wep & wpa keys with this baby
        http://www.data-alliance.net/-strse-73/Alfa-500mW-AWUS036H-USB/Detail.bok
        Please be aware all my posts and associated links are purley for educational purposes only ... i will not be held responsable if you use any of this material or links whatsoever its at your own risk!!
        I do not condone any illeigal use of any information contained within.
        No1 Automotive Contributor ? BOLLOX
        PEOPLE CALL YOU A TWAT !!!
        Greetingz too 0ptik and the TRUE
        Automotive RSE Crew
        • waqasahmed
          • 433
          #34
          Just wondering can you hack WPA and WPA2? Also, when these are "hacked" can you not then see the key, when you run windows again?
          EDIT: Must read properly first
          Lose your memory sticks? Forget to backup? Why not get 2GB of free space online, and I get 250MB too
          • Tommy123Tommy
            • Sep 2009
            • 57
            #35
            I think i found my problem
            My wireless card is an Intel, i read somewhere you need to configure the DLL files and it might work. Anyway i have a notebook i never use that runs Linux, just checked and it has a Atheros AR5BXB63 wireless car but no cd slot so im going to give aircrack ago with that.
            can i not just run it on the note book as it runs Linux ?
            • waqasahmed
              • 433
              #36
              Just wondering whats the power got to do with anything, unless of course it means you can find more wireless signals than normal?
              • Swiftie
                • 141
                #37
                Would increase your chances on the AP as it should pick up a stronger signal than a standard USB adaptor lets say.
                E Pluribus Unum
                From the one to whom much has been entrusted, even more will be demanded!
                If you have received help from this post, press the "THANKS" button to show your appreciation.
                • Tommy123Tommy
                  • Sep 2009
                  • 57
                  #38
                  Got mine working now using BT4 on usb stick , also got the intel card working, anyone know where there are any good dictionary's for wpa
                  Cheers.
                  • pvl
                    • 104
                    #39
                    @ Tommy123Tommy :
                    try this :
                    YouTube - backtrack 4 wep
                    It worked for me.
                    Have fun !
                    • waqasahmed
                      • 433
                      #40
                      tommytommy did you use a standard wireless usb or on that AP thingy with stronger signals?
                      • Tommy123Tommy
                        • Sep 2009
                        • 57
                        #41
                        @ PVL
                        i have watched them many times , i will take another look though.
                        i have used the standard cards that are in my laptops, one is a asus eeepc with atheros AR5BXB63 card and a t42 with an Intel pro 200BG, i use the atheros with bt4 and the Intel with Cain & able .
                        • waqasahmed
                          • 433
                          #42
                          Off to order myself a wifi card now
                          • Swiftie
                            • 141
                            #43
                            Cheers.
                            I was looking for one myself but never bothered to pursue it fully. If you come across one before me then do let me know.
                            Vice versa
                            E Pluribus Unum
                            • waqasahmed
                              • 433
                              #44
                              I think I might buy myself an N PCI card from eBay.com the Hong Kong seller says it supports WPA, but doesnt mention WPA2. I know Im wanting to hack in to other people's systems, but also wanting to keep mine as secure as possible
                              • Tommy123Tommy
                                • Sep 2009
                                • 57
                                #45
                                the make of card you use is pretty important, not all work with bt and some do not support monitor mode .
                                Before you rush into things i suggest you use google and read all the information you can , i know it is hard because there is a lot of conflicting information but it will put you in good stead when trying to crack your OWN keys to secure your own network ;-)
