how to hack wep key
  • krazylegz
    • 2834
    #16
    yeah it was an iso just showing up as a winrar archiver for some reason?
    i got it to start to boot up...got the clover leaf etc then it says something about checking usb devices..then errors says this should happen please reboot using ctrl+alt+delete
    PS3= krazylegz120282
    • mrtell
      • 50
      #17
      russix should just run once booted, sometimes incompatible with some hardware and it does require the right wireless adapter, i use NETGEAR 108 WG511T WIRELESS PC CARD, very good with russix. if you are having trouble with russix try BACKTRACK, very good, more powerfull but harder to get your head around. The reason for using the right pc card is that not all cards will packet the target ip, "difference being time to crack wep key, with a good card that will packet say 4 mins opposed to hours and hours.
      backtrack Remote-Exploit.org - Supplying offensive security products to the world
      backtrack contains a program called aircrack-ng, Aircrack-ng is an 802.11 WEP and WPA-PSK keys cracking program that can recover keys
      documentation-------- http://www.aircrack-ng.org/doku.php?id=simple_wep_crack http://www.speedguide.net/read_articles.php?id=2724
      took a little while but i did figure after a bit of reading and searching.
      • krazylegz
        • 2834
        #18
        thanks for the info mrtell.
        i've downloaded backtrack and will try that.
        • krazylegz
          • 2834
          #19
          anyone know the login in details for backtrack?
          i've downloaded beta4 and it boots ok but asks for login in and password before it will load up properly
          • bazzw6
            • 81
            #20
            russix tut has gone. n e chance of re-uping
            cheers
            • mrtell
              • 50
              #21
              Default password to BackTrack 4 root / toor.
              • mrtell
                • 50
                #22
                cheers
                best i can do, not watched it myself.
                {www.youtube.com/watch?v=0Lw6qeOnGVE}
                • mrtell
                  • 50
                  #23
                  looks like a good tut for backtrack
                  Tutorial: Cracking WEP Using Backtrack 3 | Whats the w0rd?
                  • ferrari_666
                    • Mar 2009
                    • 7
                    #24
                    Hello. I'd like to know how can i amplify the wireless signal. My laptop can catch a wireless signal but it is low.
                    • mrtell
                      • 50
                      #25
                      you will need to buy an adapter with a removeable antenna if you don't already have one, and then you can buy much larger antennas, some that will reach miles.
                      You can also make youself a cantenna.
                      WiFi Antennas-Super Cantenna Wireless Booster Antenna
                      How to build a tin can waveguide antenna
                      Cantenna
                      Making an 802.11 antenna from a tin can
                      • chroma
                        • 1976
                        #26
                        People still use wired equivilent protection
                        been on WPA2 AES for ages, ive not used wep since b spec transmissions.
                        even WPA TKIP is compromised nowadays and if someone compromises your network and downloads sketchy stuff like paedo shit then its you that gets prisonsexed not the culprit.
                        Boosting a wifi signal is fairly easy, you can modify a sky dish by removving the lnb and using a piece of 10mm twin and earth copper as an antenna, just trim it to the required frequency and youve essentialy got a very high gain (you can get atleast +32db if your joints are perfect) directional antenna.
                        He who laughs last thinks slowest.
                        • WATCHER
                          #27
                          Wireless WEP Key Hacking
                          look here or
                          watch it [ame="http://www.youtube.com/watch?v=TiPWUykw3uU"]here[/ame]
                          • deaddoll00
                            thanx for the tutorial
                            • kal
                              • 54
                              #29
                              Do you have a version that doesn't need burning to CD, as i am using a netbook and have no dvd/cd drive. Thanks.
                              • mrtell
                                • 50
                                #30
                                use Alcohol 52% - Emulate CDs & DVDs
                                virtual drive
                                Alcohol Soft trial version download
