Hack Network
  • zaryab
    • Dec 2012
    Hack Network
    Hi....
    is it possible to hack wifi network..
  • allnighta
    • 75
    yes check u tube for backtrack 4 wifi hack
    • TREVtheHAT
      • Jul 2010
      • 5
      As allnighta stated use Backtrack to hack WiFi. You can run it off a USB stick. It can be little bit hard to get up and running depending on the chipset of your WiFi device but it will do the job.
      • cheema68
        • Nov 2012
        Where can i get backtrack software from?
        • Galee
          • 457
          • Reapers
            • 242
            delete this
            • PremierD
              TAMINATOR
              • Jun 2009
              • 13136
              Originally posted by Reapers
              BTW I'm sure dk is against something like this
              like forum rules: Discussions about hacking or modifying cable company equipment will be removed
              footer copyright Digital Kaos does not condone any illegal operations, including obtaining premium tv for free. Digital Kaos does not accept
              responsibility for the loss of any equipment used.Everything discussed on this forum is for experimental and educational purposes only. Use
              the information at your own risk
              but is the network worth it? if you have internet already?
              The thread is an old thread .. and yes its against the rules .. and so is advertising .. so kindly remove them .. or I will
