How do I stop HACKERS???!!!!
  • jugghack2
    • Aug 2010
    • 29
    #16
    I would use WPA2 tpik rather then any other encription type
    as suggested earlyer use a strong password (lower case/Upper case letters,numbers and symbols) using a hidden SSID and Mac permit only list will make your home or buisness network as solid as possible but there is no network that is totaly hack proof you can only discurage them with the time it takes to figure out 4 or 5 diffrent means of keeping them out
    Good Luck
    Regards,
    • mbsobrinho
      • Jul 2010
      • 50
      #17
      Besides all that was said, if your router has remote administration control, like the linksys routers, you can disable it. Thus only connected via the settings can be changed ...
      • kourkoutas
        • Jul 2010
        • 25
        #18
        use a strong WPA password and change the admin password of the router
        • bazare
          • May 2010
          • 826
          #19
          try a password with a lot of characters and using all type of characters with dots commas digits etc.
          • yorugualoco
            • May 2010
            • 50
            #20
            your best option is using WPA2-AES encryption
            Advanced Encryption Standard - Wikipedia, the free encyclopedia
