How do I stop HACKERS???!!!!
  • brovver
    • 27
    Please, please help. I am using a wireless router which I initially had not protected with a password (I know i'm mad). I realised someone was sharing my connection and put on a password and changed the name, within 2 days the Hacker had taken off the password and changed the name back. I have no idea what I should do. I am using a Sweex wlan router. Please please advice!!!
  • fearghost
    • 10
    Have you enabled encryption on your wireless network? Also, change the password for the admin account on your router to something un-guessable.... Disable remote access to your router (normally you only need to do this for your home lan.
    • gazz10
      • 1015
      how did you know someone was sharing your connection?
      Change login/pass to router and dont have it a common name add characters to it.
      Just do a reset of your router if its been changed and you cant get in , little reset button at back.
      then make it wpa encryted.
      • mrtell
        • 50
        Most important, dont use a WEP key, use a WPA key.
        I can break a wep key in about 4 mins and i am no expert, also when using a WPA key use a combination of letters, numbers and symbols that don't make sense, if you use a dictionary word the key can still be cracked by using a brute force dictionary attack.
        • firemouth
          • 410
          good advice, mind you replacing one letter with a number, in a dictionary word, does exactly the same thing. no amount of brute force will sort that. but it wont stop the determined hacker. if you use a program like Network magic, you may be able to find their ip address. if so place it in the restriction section, so the router refuses connection, whatever passwords they have.
          Firemouth rules for life.
          If it aint broke, don't fix it!
          If its broke, fix it and use it again!
          If it proper broke, use it for something else!
          • hopper28
            • 119
            what I have done was first change the password for logging into your Router and then setup the router to only accept connections from MAC address only, this way even if they have your password the router wont connect to their computer unless that MAC address is listed in the allowed section.
            • on_the_jazz
              • 557
              MAC filtering is pointless. He'll just sniff a MAC in use and change his MAC address to that.
              Just do whats been said -
              1) change your router password.
              2) use a strong WPA password.
              He won't be able to get in for a long time if you do this (and if you haven't had a pc inside the network exploited).
              • hopper28
                • 119
                That is what I said change the password and limit to mac address extra protection.?
                • firemouth
                  • 410
                  well exactly, only don't bother with the MAC bit. if you change your password on a regular basis, they will, most likely, never get back in.
                    Use WPA and use a phrase with spaces as password. No ~~~~er will get in that
                    • firemouth
                      • 410
                      consensus seems to be, a GOOD password is the best defence. it should not be that hard to work out really. just change your current passwords for both the Router access and the wireless access. it does not matter how many times he has been in, a new stronger password will do the trick. and it only takes about 5 minutes to do.
                      • bahooo
                        • Sep 2009
                        range
                        If possible you could decrease the range by lowering the transmit power.
                        • hrabe
                          • Jul 2010
                          • 15
                          hide SSID too...
                          • v5uk
                            • Jul 2010
                            • 59
                            block the rouge IP so he cant get into it
                            • starsky
                              • Jul 2010
                              • 35
                              Reset router, change admin password, make wireless password difficult, encryption type WPA or WPA2
