not sure i in right forum but im on the look out for one of them digi senders wanted to know if anyone can recomend one and whats the signal like with them
I got one out of Argos for about 20 quid.Quality is excellent as long as your not plugged in near a microwave etc.
I use a video sender to send the picture upstairs.
http://www.maplin.co.uk/Module.aspx?...ender&doy=21m5
It has a sensor so that you can use the remote from another room too.
Only problem is If you have a Wii or other wireless devices on it will interfere with the signal.
Reason: link changed
The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
By a sender that does not run on 2.4Ghz, Maplin sell senders that run at 5.8Ghz then you will get no wifi interference.. Not cheap though, cost is ?69.99
However further investigation into these show that there was two models, basically you need the new 'fixed' model that works with VM and Sky, Maplins stock is all new according to Emprex who make these things.
Some people had complained about the previous versions going fuzzy when you walked around the room and some mush had a theory that if the ceiling plasterboards were the foil backed ones then that would also interfere. Basically like any product most people have an opinion either good or bad, but at least it does not interfere with wifi, bluetooth, cordless phones and microwaves
Still stay 5.8Ghz is the way forward, more will start making them soon...
