Hack wifi?
  • phamhuy
    • Apr 2010
    • 9
    Hack wifi?
    i want to hack wifi? please tell me how to hack? i use win 7
  • DNG2010
    • Mar 2010
    • 369
    Secret is "Aircrack-ng". Google it and you will get all your answers!
    DNG
    Due to a severe downturn in the economy the light at the end of the tunnel has been switched off until further notice.
    • wahooo
      • Aug 2009
      • 72
      Ur best hope is Backtrack which is a Linux OS and if you don't understand that platform is gona be HARD
      • dasteph
        • 1293
        i think you will find posts/disscusion on hacking are frowned upon on dk.
        • DNG2010
          • Mar 2010
          • 369
          BackTrack Linux - Penetration Testing Distribution
          Well there is Aircrack-ng for windows, so it does not have to be only with backtrack. But i do prefer backtrack but a lot of people don't know Linux.
          DNG
          • N3lson
            • 18
            Yes, aircrack etc can be run in windows, but the list of FULLY compatible wireless adapters is pretty short, and some need you to go find custom drivers to enable monitor mode....
            Backtrack comes with all the monitormode-capable drivers built in, supports a lot more cards than Windows can, and has nice tools like Gerix to automate the whole aircrack/mon/dump suite for beginners.
            • jif
              • Jul 2010
              • 52
              this might help
              • kreller
                • Aug 2010
                • 49
                I only have a guide in danish.
                • megabob
                  • Aug 2010
                  • 8
                  You can hack only WEP protected router
                  There is no fast solution for WPA and WPA2
                  For WEP hack aircrack is the soltution
                  • ricopicouk
                    • Aug 2010
                    • 51
                    However, you cannot just find a WEP access point and gain access to it. The WEP hack relies on someone logging onto the access point whilst you are monitoring it.
                    Your computer then captures the data required to pair with the access point and decodes it, to find the key. This can take a lot of time, or little time depending on if anyone logs onto the network.
                    • megabob
                      • Aug 2010
                      • 8
                      Yes is easier if there is someone allready connected to the acces point, but if I remember well you can generate connect paket and this help a lot for findfing a WEP key
                      The last time a did the job, it take about 5 min with someone connected, and less than a hour with nobody on the access point.
                      I dont know if there is a lots of access point still using WEP in UK, but here in France, it is very hard to find now
                      • digitalbac
                        • Feb 2010
                        • 99
                        It's true, and also when the access point authenticated the client with mac address !
