wireless network wont connect
  • lorrick
    • Jul 2010
    • 9
    hi...my wireless netgear wg 614 wont connect to my laptop despite all correct lights working and moving it closer and about to no effect...i must say it did work before ....ithen went and bought a o2 dongle while away but when i try to connect without the dongle it comes up cant find wirless network router ...even though wireless light on......anybody help please....
  • RSwire
    • 1247
    Can you run a detect wireless device? My laptop has an embedded device but I can shut that down and detect a wireless or wifi device. Using the dongle probably shut your wireless router option down because it didn't need it.
    Hope this helps.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
    • lorrick
      • Jul 2010
      • 9
      hi...thanks but unsure if my laptop (advent 9912) windows vista home premium has a wireless device to shut this down and can you tell how..... as this just happened after i installed the dongle .....ta
      • dasteph
        • 1293
        go into control panel/network and sharing centre in the box click connect to network it should list your wifi if its is picking it up, if it is you should be able to connect to it.
        • mak21
          • 27
          I think the easy way is to just test if u uninstall the new softwar if u can connect or not, then we'll know where to look!
          • andaras
            Hi there,
            i think this could be a hidden wireless Network. This is a configuration in your Wireless Router.
            Connect your PC or Laptop with Cable to the Router and Login to it.
            Look for Wireless Configuration and for "Hidden Network".
            Disable the "Hidden" Part and store configuration and Reboot the Router. Now you should be able to connect.
            Regards, Andreas
            • Reapers
              • 242
              i agree with andaras
              you could just disable the Hidden SSID on the
              browser web interface to let the laptop see the
              router then connect using your encyption password.
              or
              if the wireless manager on the laptop has the setup
              to connect to a hidden network all you should have to do
              click on that enter the Wireless SSID name then
              encryption password.
              also other things might apply.
              Realtek 8169/8168/8101
              Billionton GMEWLGRL-2 (RaLink RT73 USB) Wireless LAN
              what type is your wireless?
              G or N? sometimes that matters
              not if the router not configured because usually default
              accepts both but sometimes routers are setup just for N
              check on whether the router accepts G and N
              your wireless and the frequency on the web interface
              some routers can be set to certain devices only.
              sometimes its better reset the router and work from the start
              because you know where you are at.
