i just got sky broadband in and the router they gave me connects via a ethernet wire to my laptop,when i was on virgin i didnt need to hook any wire to my laptop,any ideas.cheers
skybroadband
Tags: None
Have a look here m8 this should help you out http://www.sky.com/Assets/PDF/StaticFiles/1555810.pdf
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
ive one all that but ive got to keep the ethernet cable in my laptop,cant diconect it or it will go off,should have just stayed with cable.Comment
It's been years since i had ADSL. When you finish the initial setup can't you unplug the ethernet and pick the wireless connection up, on the laptop. Why does the ethernet need to be still plugged in after the initial setup ?
it stopped when i took it out maybe im doing it wrong .so can u connect on ur laptop once you have done the set upComment
You need to set the router up initially using the ethernet lead, you should be able to disconnect the lead and connect wirelessly after that. I;m sure someone will either confirm this or tell me i'm talking shite
