pc problem
  • angrycat
    • 165
    pc problem
    Keep getting pop ups enable realtek audio device switch
    I done this but still the pop up comes up, its very anoying
    any clues buddies ?
  • Street Hawk
    • 156
    is your sound card onboard?? and do you know what driver/software version your using?
    • dctyper
      • 2539
      realtek are usually built in to the motherboard, do you have sound card attached
      Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
      previous life dm800hd and 500c on cable screw you nag3
      • angrycat
        • 165
        No its built in to motherboard
        • Walkinmyshadow
          • 712
          Disable it m8... Click start/run, type in msconfig and click ok, window opens, click startup tab, and there should be a startup item called rthdcpl on the list somewhere, disable it and reboot, after reboot it will ask if you want selective startup or normal startup, click selective startup and that should be it
