hp pavillion dv5 1110em
  • johnb34
    I have a hp pavillion dv5 1110em and around 8 months ago it started crashing and the screen freezing with blue horizontal lines,since then ive had the hdd replaced,memory replaced and the motherboard replaced and it still overheats and crashes,anyone else had these problems with this model,im starting to get peed off now
  • AbsoluteFire
    • Mar 2010
    • 78
    This should really be in the PC problems area.
    However, you say it overheats? When the motherboard was replaced was the CPU cleaned up and re-pasted and was the heatsink screwed down tight enough.
    When you switch on have a look in the bios and see what CPU and System Temps you are getting. Some bios' don't have it and you'll need to grab a windows based temp tool.
    • caveman_nige
      • Feb 2008
      • 4920
      moved........
