blue screen of death
  • jinkie
    • Apr 2011
    • 43
    hello i was looking for help with this my laptop has stoped working and this screen has came up with the error 0x0000007B (0x80786b58, 0xC0000034, 0x00000000, 0x00000000). is there any way of fixing these i have tryed to run safe mode but it does not let me run anything thanks for any help i am running windows 7
  • smoggy
    • Apr 2009
    • 12772
    googling that error gives plenty of hits and seems to suggest the error is associated with an inaccessible boot device
    have a read here in particular number 8 STOP 0x0000007B - STOP 0x7B INACCESSIBLE_BOOT_DEVICE - Fix STOP Error 0x0000007B
    • jinkie
      • Apr 2011
      • 43
      i have removed the harddrive and replaced it with the harddrive from my old laptop and tryed to install windows 7 but still the same prob
      • pk.evolved
        • Mar 2010
        • 292
        Have you messed around with BIOS. If you did you may have changed HDD SATA mode (AHCI or IDE). Try fixing that in BIOS.
        Good luck !
        • jinkie
          • Apr 2011
          • 43
          thanks for helping but i dont know how to change anything in bios how do i do that
          • pk.evolved
            • Mar 2010
            • 292
            It depends who is laptop manufacturer and what model is it.
            But if you haven't changed anything in BIOS, I don't think that SATA mode is the problem.
            • jinkie
              • Apr 2011
              • 43
              the laptop is a asus k5oij and i was using windows 7
              • pk.evolved
                • Mar 2010
                • 292
                ok, when you power on your laptop, you will have to access the bios by pressing certain button, as shown on screen (for example "PRESS F2 to enter setup" or something like that. When you access bios, you will have to find something like device configuration or similar, and from there hdd settings and change the hdd mode. I can't tell you all in details because I don't know how does your laptop bios look like.
                • jazzipup
                  • 14
                  Does it give anything errorwise like "Inaccessible boot device" ?
                  Did you install any new drivers or software prior to it failing/blue screening?
                  • pk.evolved
                    • Mar 2010
                    • 292
                    yes, reason can be new hardware , drivers, etc.
                    But I don't think that new drivers are problem since he used new hdd for new win installation, and again got the BSOD.
                    " STOP 0x0000007B - STOP 0x7B INACCESSIBLE_BOOT_DEVICE - Fix STOP Error 0x0000007B" that is the error mate, so i think that the conf. in bios (hdd mode ) is the reason.
                    • jinkie
                      • Apr 2011
                      • 43
                      thank you for all your help i tryed changing things in bios and that worked its loading windows 7 so again thanks
                      • pk.evolved
                        • Mar 2010
                        • 292
                        No problem, DK is all about sharing and helping.
                        Regards
                        • kaToo
                          • Feb 2010
                          • 780
                          hi
                          I have the solution
                          I have same problem with acer aspire
                          All you have to do is
                          Open motherboard and than Solder the Grafic card procesor
                          How to do It :
                          If it has Integrated graphic you with se the graphic card procesor
                          Than you need to solder it with hot air
                          all you have to do is put hot air uper the graphic procesor and pull it down with something when soldering and let pc 1 minute and after that you will start it without problem
                          P.S sorry for my english
                          • enterprise1701
                            • May 2011
                            • 107
                            Originally posted by kaToo
                            I have the solution
                            How to do It :
                            • jetdede
                              • Nov 2010
                              • 410
                              my god...u can make motherboard broken
                              DK is The Most Valuable Site my friend
                              Don't forget to do it
                              right place to share each other, not to
                              Don't do it when you sleep, will make big cost
