Loud fan noise and screen wont come on
  • lee_hdi
    • 928
    Hi,
    I have a Dell tower pc, pretty old running XP. It worked fine then all of a sudden the fan is really loud near enough as soon as you press the 'on' button and also the screen doesn't come on, it is as though is on stand-by [get the amber light rather than green].
    I've attached a video and a couple of pictures.
    [ame=http://www.youtube.com/watch?v=c5vFClUh_z0]YouTube - ‪14062011016‬‏[/ame]
    When I opened it up there was a lot of dust so I cleaned it all out, but it hasn't made a difference.
    Any idea what the problem could be?
    Thanks,
    Lee
    Don't let failure go to your heart, don't let success go to your head.
  • cgscott
    • 3513
    Reckon the PSU (Power supply unit) is gone.
    Try another PSU and see what happens
    Patience is a virtue.
    • lee_hdi
      • 928
      Again?
      That will be the third one it will have had
      • ghjoker
        • Feb 2011
        • 6
        It looks more like a CPU owerheated and dead... Dead PSU wouldnt make the fan go crazy...
        • cgscott
          • 3513
          Always start with the psu but yes it could be a blown cpu.
          • MrFug
            • 880
            The CPU heatsink and the securing clip don't look too healthy. Maybe it's not making sufficient contact with the chip.
            • bill4676
              • 74
              not the poet supply if it were you'd get nothing no lights or fan more the processor gone down also test your ram
              • lee_hdi
                • 928
                Does that mean a new motherboard then?
                Or can the CPU be easily replaced?
                • R_J
                  • 492
                  A lot of those pc's will run the fan full speed untill it boots, (some emachines do) I would start by reseting the bios, remove the battery and change the jumper to reset the bios, it may need to sit for a while if that don't work then remove the memory and see if it will try to start up. I have had motherboards lock up and not do anything and after reseting the bios they worked fine.
                  • Instigator85
                    • 14
                    High Density RAM
                    I noticed the RAM installed is high density (chips are only on one side) which means your memory will be running in single channel mode. Low density has chips on both sides of a stick of ram and allows the pc to run in dual channel mode. If you have even one high density stick installed all the rest will be slowed down to single channel mode... Just an observation for better PC performance.
                    • Instigator85
                      • 14
                      If you are continually blowing PSU a surge protector board would be a good investment.
                      • Instigator85
                        • 14
                        CPU's are easy to replaced as long as you get a replacement that is the same size and compatible with the motherboard.
