How to Find my Lost Computer Password
  • indivolc
    • Jul 2011
    • 6
    How to find computer password quickly that I Can anyone help me reset forgotten computer password? Any helps will be appreciated! - Now check the following ways on reset lost computer password!
    Firstly, use password prompt function on password locked computer
    If you have set the prompt option when you set account password, it may help you remember something about your forgotten computer password!
    Secondly, reset computer password with default administrator account
    Once we install Windows OS, there will be automatically generated an ***8220;Administrator***8221; account with blank password. Therefore, if we forgot password on computer, we can have a try:
    a. Boot system, and press Ctrl + Alt + Del keys twice when the Windows login screen comes up.
    b. At the Classic Login window, input: Administrator and keep Password box null. Then press Enter key to login.
    c. Recover computer password by: Control Panel - User Accounts. Thirdly, find computer password with computer password reset disk
    If we created this computer password reset disk before we forgot password, we can opt for the disk to help us unlock password efficiently.
    a. Click OK and close the message box on the password incorrect prompt window.
    b. Click ***8220;Reset Windows Password***8221; and insert the password reset disk.
    c. Do as the ***8220;Password Reset Wizard***8221; to create a new password. Fourthly, change computer password with Windows Installation Disc
    Take computer Windows XP as example:
    a. Start computer using Windows XP Setup CD.
    b. When it asks to repair our current Windows installation, choose ***8220;Accept***8221; it and press "R" to run the repair. Then computer will begin to repair our Windows and copy files to hard drive.
    c. Setup will reboot system. Please don***8217;t press any key when there is ***8220;Press any key to continue...***8221;
    d. Now computer will do other tasks and there will be a progress bar displayed. Please notice carefully the details shown at the bottom of screen.
    e. Once "Installing Devices" comes up, press <Shift>+F10. Input: nusrmgr.cpl and press <Enter> at the Command Prompt window.
    f. The same "User Accounts" window will display as it is in Control Panel. Choose ***8220;Administrator account***8221; and select any account listed to change or remove your computer password. Fifth, break computer password by DIY a password recovery disk
    If the above four methods still can***8217;t help us reset lost computer password, we can refer to this way now. DIY a password reset disk after forgotten computer password means that we burn an .iso image file from Windows password recovery software into a bootable CD/DVD/USB disk. Now, take one of the top-rated Ainorsoft Windows Password Recovery Corporation as example:
    a. Download and install Ainorsoft Windows Password Recovery Corporation in any accessible computer (not from computer you want to unlock)
    b. Burn an ISO image file to CD/DVD/USB Flash Drive
    c. Set locked computer to boot from CD/DVD/USB Flash Drive and set the BIOS Setting for CD/DVD/USB Flash Drive.
    d. Reset forgotten computer password to default Re123456.
    The above ways on forgotten computer password reset are the collections of best bet for us to unlock So even if we forgot computer password, things will be OK soon!
    source:
    Last edited by gmb45; 18 September, 2011, 06:30. Reason: to handy with the links m8
  • jazzipup
    • 14
    I remember this happening to me once. If you get a copy of Windows PE, there's a password change tool in there.
    • Lyrrad
      • 484
      Try this option
      Password 4shar1ng
      • jetdede
        • Nov 2010
        • 410
        we can use hirens boot cd too...inside it has tool for reset admin password...have use it for long time
        DK is The Most Valuable Site my friend
        Don't forget to do it
        right place to share each other, not to
        Don't do it when you sleep, will make big cost
        • nomodells
          • Aug 2011
          • 6
          lost xp ? password
          When I am asked to help with a lost password for XP, I try this method... boot to safe mode try administrator account with blank password. If you get in, START> RUN> type control userpasswords2 Enter> choose the account and at the bottom of window is a reset password button
          it will work from any admin account if it is a shared PC also
          • dieselenginecat
            • Jul 2011
            • 122
            I've got this problem too for few months ago....I use hirens boot CD and it's working good....it's reset the admin password...
            u will many software here
            each other
            beautiful place that we can make our ended
            Many thanks to gmb45 for help me better
