Can't access BBCiplayer
  • clem58
    • Aug 2009
    • 819
    At the weekend i tried to log on to BBCiplayer but was meet with a message telling me that my IP ADDRESS is not in the uk. To-day i phoned virgin, they claim to be baffled by this saying that my IP ADDRESS is uk based. I have since discovered that i have the same problem with my PS3 there's no message, just the IPLAYER as you would expect to see it except it won't open any programmes. The guy on the VIRGIN HELPLINE tried to help sort it out by first checking if i was using a PROXY SERVER. alas he could find no problem with any of my equipment. He tried to compensate by telling me i could use a proxy server to log on. Can any of you guys enlighten me as to whats maybe goin on and how it can be sorted out. THANKS IN ADVANCE FOR REPLIES.
    After thought! my son in law installed a new HDD and increased my RAM by an extra GB into my laptop, is there a possibility the problem could be mechanical that said i don't have any other problems.
  • clem58
    • Aug 2009
    • 819
    [QUOTE=clem58;1204141]At the weekend i tried to log on to BBCiplayer but was meet with a message telling me that my IP ADDRESS is not in the uk. To-day i phoned virgin, they claim to be baffled by this saying that my IP ADDRESS is uk based. I have since discovered that i have the same problem with my PS3 there's no message, just the IPLAYER as you would expect to see it except it won't open any programmes. The guy on the VIRGIN HELPLINE tried to help sort it out by first checking if i was using a PROXY SERVER. alas he could find no problem with any of my equipment. He tried to compensate by telling me i could use a proxy server to log on. Can any of you guys enlighten me as to whats maybe goin on and how it can be sorted out. THANKS IN ADVANCE FOR REPLIES.
    After thought! my son in law installed a new HDD and increased my RAM by an extra GB into my laptop, is there a possibility the problem could be mechanical that said i don't have any other problems.[/QUOTE
    sorted the problem was caused by OPERA i'm now using explorer.
    • thewizardofodds
      • 924
      OPERA goes through us proxies for some reason
        That's interesting! Could be useful.
        • Reapers
          • 242
          apparently this is not a lone problem a few peeps have this issue
          For Reference
          BBC iPlayer - Help - I'm in the UK but told that I'm not, what should I do?
          so might want to check with the isp again.
          but here some other things as well.
          if have used any proxies in the past or any programs that use or
          had access to change your network ip?
          sometimes programs that use proxies even removed there settings
          remain or when people have used them might of forgot the remove them
          things that are common with proxies
          standalone programs if you havent had any thats fine just need to
          check your in the search box type cmd then ipconfig/all
          Browsers firefox and opera sometimes you will need to check the
          network settings in the browsers and reset them to default if they have
          been used with a proxy.
          sometimes even certain security packages come with parts in the softwares
          which give anonymity as well so check your security
          if none of it work you might need to resort to resetting router and modem so
          it restablishes with the isp and it renews the addresses.
