Internet disconnection
  • clem58
    • Aug 2009
    • 819
    Over the last 5 or 6 wks my wireless router is disconnecting from my laptop, i go through the usual routine of resetting the router. this happens maybe twice 3 time a day. This all began about 6wks ago when there was a fault in the area. That said, it happened before i posted this message, but it just so happens that it didn't disconnect from the skyplayer on the XBOX. Any thoughts before i fone virgin.
  • cunny
    • 4915
    What make/model of router? But sounds like an issue with laptop not the router.
    Have you tried anything with laptop? Will need to know operating system ect
    • clem58
      • Aug 2009
      • 819
      Netgear, i had a new hdd installed and my ram was increased be a gb. Thats the laptop i'm talkin about i don't keep sheep. I didn't install it my son inlaw did it. The mechanic's of these these things is lost on me. but if its easy to rectify i'll maybe give it a go. Windows 7
      He recently installed windows 7
      • cunny
        • 4915
        Things i would do are :
        Reset router to factory default (using the reset button on back)
        Reset al router security once done.
        Connect with laptop.
        Monitor.
        If still persists, look at network drivers (google your make and model of laptop and you will find them)
        If still persists, maybe change channel of wireless.
        After that, you could start looking at rolling back the operating system or a format see if that cures it.
        It could be that the wireless adapter has become faulty and might need to get a new 1
        • irishbluestaffy
          • 611
          open yr network and sharing center from bottom right corner go to network manager remove your router from list then search again for router this should sort it out as a friend had this problem by me and this is Wat i dun for him and it has worked perfect since then,hope it helps
          • cactikid
            • 12017
            any other wireless devices in house as i had the same problem and found out it was a wireless sender to games chair was the problem,it has been ok for last 2 months as sender not switched on.
            • lolooo1981
              • Feb 2011
              • 471
              Do you use dongle in your laptop for wifi connection or internal pci integrated wifi?
              Because dongle is bad solution cause of sleeping usb mode of windows.It cause many problem of windows user.
              After, more information is needed, What configuration and operating system ?
              Best regards
              Original Kwp2000+ and other...
              No stress for all !
