Need help on Dell Latitude D520 Adimistrator Password..
  • smoggy
    • Apr 2009
    • 12773
    #31
    Originally posted by jabba1000
    xraydelta101 hope you can help me here mate i have a Dell D520 locked BIOS, i have a password which lets me load up windows but isnt a password to play with BIOS my tag is 8N68D3J muchly appreciated.
    first post should be here Introduce Yourself
    say hello and join the community
    in the meantime try f0tadnrw 2nd is a zero
    • tnaeem
      • Mar 2013
      • 15
      #32
      Dell Latitude D520 Password Reset
      smoggy, i am still facing problem, i had two laptops in my computer lab, both were toshiba, due to no display I replaced both of HDDs in Dell D520 that i have as replacement unit. But due to HDD password both laptops showing statement,
      "the system primary HDD, is protected by a password authentication system, type correct hard drive password to unlock. so i need hard drive password.
      1: Hard Disk #**40GIB7CLB
      2: Hard Disk #B00LGCPJ8JA
      plz help me with thanks.
      • smoggy
        • Apr 2009
        • 12773
        #33
        passwords can be generated but they only work on the original HDD
        • Alexandre3
          • Mar 2013
          • 4
          #34
          Hi friends i am a computer expert here i just want to say you the solutio to remove the password of your windows logging in you just press the alt+ctrl+del and give the name of administrator and enter without entering the password you are successfully loged in the windows or if you have BIOS password then you can try tit to remove the cell and then check it out
          • tnaeem
            • Mar 2013
            • 15
            #35
            Ok, then how can i unlock the hard disks password.
            1: Hitachi 120gb, model: HTS543212L9SA00, serial: 081017FB0B00LGCPJ8JA, IEC S/N: 2GR100J8YR0YBA.
            2: Toshiba 320gb, model: MK3265GSX, serial: 40GIB7CLB, IEC S/N: 2PA200J82N77VN.
            Plz help if possible. I will be greatful to you.
            • Juas222
              • Mar 2013
              #36
              D520 Admin Pass
              Hello!
              I've the same problem like other users. I've a second hand Dell Latitude D520 (for my father's enterprise), and it has Admin Password in the BIOS. I can access BIOS, but some features are locked and I can't switch on/off them (Wifi, IR, Bluetooth...) Can anyone help me? I'll be really grateful.
              The Service Tag is: 9G4RX2J-595B
              Sorry for my English.
              Thanks!
              • smoggy
                • Apr 2009
                • 12773
                #37
                Originally posted by Juas222
                Hello!
                Thanks!
                in the meantime try r27tf3jm
                • Juas222
                  • Mar 2013
                  #38
                  Originally posted by smoggy
                  ...in the meantime try r27tf3jm
                  Wow! It has worked correctly!
                  Thank you so much!
                  • thiagomaia32
                    • Mar 2013
                    • 7
                    #39
                    Dell Latitude D520 Bios Admin PSW
                    Hello Smoggy!
                    I've the same problem like other users. Someone configured an Admin Password in the BIOS. I can access BIOS, but I can't change some features. Could you help me in this case?
                    Service Tag: DF0J2F1-595B
                    Thanks in advance!
                    • smoggy
                      • Apr 2009
                      • 12773
                      #40
                      Originally posted by thiagomaia32
                      Hello Smoggy!
                      Thanks in advance!
                      try sag3eo7d 6th is o for one
                      • thiagomaia32
                        • Mar 2013
                        • 7
                        #41
                        Thanks Smoggy! You're great!
                        • hipotalamo
                          • Mar 2013
                          Hello Smoggy!
                          Service Tag: FTCZN2J-595B
                          Thanks in advance!
                          • smoggy
                            • Apr 2009
                            • 12773
                            #43
                            Originally posted by hipotalamo
                            Hello Smoggy!
                            Thanks in advance!
                            in the meantime try 9ysn0x6c 5th is a zero
                            • smae801
                              • Apr 2013
                              • 6
                              #44
                              Hello there I could really use some help I need to find the admin password for my dell latitude d520 service tag hvq1yc1. I can use any help anyone may have. Thanks
                              • smoggy
                                • Apr 2009
                                • 12773
                                #45
                                try 0v0iacbg 1st and 3rd are zero's
