bios password acertravelmate 2420
  • kadeleck
    • Feb 2010
    • 250
    please master code for travelmate 2420
    syteme disabled [07233]
  • karlpowell
    • 189
    have you tried the pheonix bios recovery disk , you will need a bootable floppy or usb and the bios recovery files then as you boot the laptop hold (I think ) CTRL and tab ... google is your friend for the files .
    • karlpowell
      • 189
      oops double post
      • Captin
        • Mar 2010
        • 129
        I had a Travelmate 2410 and tried everything possible, reset disks master codes everything, in the end I just lifted the keyboard and used the cmos reset switch.
        "Opinions are like arseholes. Everybody's got one and everyone thinks everyone else's stinks."
        • karlpowell
          • 189
          OK, here is my guide to Remove Acer Bios password computer via Software. This has been done on testing machine Laptop Acer Aspire 3620/ Travel Mate 2420. Anyway, I'm not sure it will work on every Acer PC/Laptop so just consider to do at your own risk, I***8217;m not responsible for any damages caused by this guide.
          As we know most of Acer computer (Laptop & Desktop) allow us to setup BIOS in Microsoft Windows (9x/XP/Vista) environment. Great, this is the powerful that help us to remove the BIOS password because all we know if we enter Setup Utility at the boot time we have only three times of filling the password and if all wrong then the system will halt.
          The program helps us to enter Acer BIOS setup in Microsoft Windows is ***8220;Acer eSettings Management***8221; which comes with the CD when we buy Acer PC/Laptop. If you lost the CD then just come to Acer website to download the program.
          Before you can install ***8220;Acer eSettings Management***8221; you have to install program called: ***8220;Acer Empowering Technology***8221; so you***8217;d better to download both of them from Acer website and install & restart your computer to be ready for the job. Here is the link of Acer website, just come there and sellect right series/model of your computer to download these programs:
          Code: ftp://ftp.support.acer-euro.com
          Code: ftp://ftp.work.acer-euro.com
          Another one program is also very important we will need called: ***8220;CmosPwd***8221; - CmosPwd is a cmos/bios password recovery tool. CmosPwd is under GNU Public License. You can freely distribute it. It can be compiled under Dos, Windows, Linux, FreeBSD and NetBSD.
          Download it here:
          Code: http://www.cgsecurity.org/cmospwd-5.0.zip Guide to install CmosPwd and remove password:
          1. Download & extract to a folder. I put it in drive D like this: d:\ cmos
          2. To work on cmos memory, ioperm need to be installed and running. ioperm gives direct port I/O access for specified ports to user-mode process (ring 3) using Ke386SetIoAccessMap and Ke386IoSetAccessProcess kernel functions.
          Log on to Windows as Administrator priviledges and do as follow: (see picture):
          a. Click Start-->Run: type CMD hit Enter on your keyboard.
          b. now us the CD command of Dos to come to d:\cmos\windows. (here is: d: hit enter; cd cmos hit enter; cd windows hit enter).
          c. when you are already in d:\cmos\windows in drive D then: type ***8220;ioperm.exe ***8211;i***8221; hit enter.
          d. to start ioperm service: type ***8220;net start ioperm***8221; hit enter.
          e. ok, type: ***8220;Cmospwd_win.exe /k***8221; hit enter, we will see:
          1 - Kill cmos
          2 - Kill cmos (try to keep date and time)
          0 - Abort
          Choice :
          Type 1 and hit Enter to clear cmos.
          f. run the Acer eSettings Management program: start-->program-->Acer Empower Technology-->Acer eSettings Management.
          g. now come to the: Bios Password to see: if you still see password enable, that means we fail but if we see they are Disable so we are done. Remember if we success remove password then we have to create a password for it and then remove it and click Apply to save to cmos memory. This is very important because sometimes we see it Disable but when reboot the computer they are Enable again cuz the password is still in the CMOS.
          That***8217;s all, good luck & don***8217;t forget to set an easy password later
