packardbell notebook problem
  • grapam
    • Feb 2010
    • 9
    advice required i have a packard bell easynote mit-sable-g notebook, the problem is it will not power up when i plug the mains adapter in and switch it on. all i get is a red battery charge light when i press the start button the red light goes out, does the fan need to be running before anything else powers up, any advice would be most appreciated
    thanks doc
  • scottek
    • Oct 2011
    • 12
    thanks doc
    You could check the DC power jack on the notebook to make sure Your adapter plug is fitting properly and secure , ie , not loose internally on the motherboard . (bad solder joint)
    Red light means a "no charge" condition right ? The system fan(s) should power on as the laptop does its' POST or power on self test .
    • grapam
      • Feb 2010
      • 9
      thanks i will check the DC connection first, i think the laptop may have been dropped so the connecter, once again thanks
