looking for msi motherboard drivers
  • tamgunner
    • 691
    hi all im looking for a few drivers for my msi MS-6367 hp pavillion desktop pc.
    im looking for ethernet,multimedia and sm bus contoller. ive been on the hp website and the msi website but i cannot find drivers anywhere. pc is running xp.
  • sean00
    What model is the desktop? 400, 700 etc?
    • R_J
      • 492
      I found this information MS-6367 Drivers
      Try this driver from NvidiaWindows XP - nForce UDP (v1.0)
      coulld it be a HP Pavilion 443.uk Desktop PC? if it is try these drivers HP Pavilion 400 Desktop PC series- Download drivers and software - HP Business Support Center
      I also found this Manual if it can help http://217.110.237.70/Manuals/6367-engl%20v1.0.pdf
      • Cod3waX
        • 1011
        this is what u need if u ever have a computer that dostn install network drivers on fresh install
        [ame=http://www.amazon.co.uk/USB-Ethernet-network-adapter-RJ45/dp/B000J0H6YY]USB 10/100 Ethernet network LAN adapter to RJ45: Amazon.co.uk: Electronics[/ame]
        • tamgunner
          • 691
          its a 463.uk mate
          • tamgunner
            • 691
            thanks had a look but the hp website doesnt seam to have any drivers for any models close to what i have
            • delboy13
              • 415
              have you tried using a driver software like driver magician
              • tamgunner
                • 691
                dnt be daft ive never used software like that dnt like it
                • R_J
                  • 492
                  Did you try the nforce udp driver pack? That should cover the onboard chipsets. also you never did post the actual model of the pc.
                  • Reapers
                    • 242
                    sorry im a bit mixed up whether you wanted xp or windows 7 on this system.
                    i think i've found your pc model though
                    hp website is stating the drivers are for windows xp only so that could be an issue if you want windows 7 anyway i thought id send the link to see if its any use to you.
                    its only asked for people to buy recovery kits which include drivers
                    HP Pavilion 463.uk Desktop PC - HP technical support (United Kingdom - English)
                    HP is currently in the process of testing and qualifying drivers to support the public release of Windows 7.
                    Drivers are posted to the HP Customer Care Website as soon as the drivers have completed a testing and qualification process.
                    These drivers are intended for use in the full release version of Windows 7.
                    from page
                    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01778879&tmp_task=useCategory&lc =en&dlc=en&cc=us***10216;=&product=3069
                    Must be still working on the drivers for windows 7 on the older model computers.
                    im with Cod3waX and R_J
                    if you plan to upgrade anytime to windows 7 you would have to look for alternate drivers.
                    specifically the motherboard (
                    MS-6367 (Mambo))
                    • tamgunner
                      • 691
                      from page
                      MS-6367 (Mambo))
                      thanks i managed to find drivers for it.
                      • Saltire
                        • 1361
                        In situations like this all a person needs to do is run the free trial software of a program called aida64 or everest (same thing but different versions).
                        Then you will get all the info you need about all the hardware inside the pc including the exact motherboard model etc and then simply go to the motherboard manufacturers website and download all the available drivers for your board, and thats it, simple as that, if the motherboard manufacturers website fail to update the drivers on thier site then you just go to the chipset manufacturers website that make the chips on the motherboard such as intel or nvidia etc and get the drivers directly from them for the chipsets, again, aida64 and everest will give all details needed, easy peasy lemon squeezy,
