Down key sticking
  • stebarker
    • Apr 2010
    • 37
    Down key sticking
    Hi
    The down key is playing up, you can only "tap" it to move down, you cant keep it pressed down it doesnt move
    Any ideas of how to fix it, ive cleaned the keyboard already
    ste
  • pk.evolved
    • Mar 2010
    • 292
    Try to remove it from keyboard, and see if something got stuck in the empty hole or area that is used for pressing down the key (that is if you are using desktop PC). If you are using notebook it might be similar problem or it could be something with the key mechanism. Also try to remove it, but carefully so that you don't damage something. If it's something that got stuck, remove it, and if it's the mechanism (assuming that's not broken) try to set it right.
