driver problem windows xp
  • JIMCEE
    • 94
    Hi guy's, i am having a prob with the following. when logging on sometimes i get the following message, THE SISGU DRIVER IS NOT WORKING PROPERLY- REBOOT THE SYSTEM TO RESTORE FULL DISPLAY. done that its still the same. get the following message, THE NEXT TIME YOU REBOOT A DIALOG WILL BE DISPLAYED GIVING YOU A CHANCE TO UPLOAD DATA. the dialog shows the following script- BCCode1:ea -BCP1:83B97D10 -BCP2:841DE648 -BCP3:841A85A0 -BCP:0000000001 -OSVER5_1_600 any help in fixing this most annoying prob would be appreciated, and explained in easy terms how to sort it as i am not pc clever, cheers
  • dasteph
    • 1293
    the following link is to sis driver dowload page.
    Sis.DriversUpdated.com
    • dasteph
      • 1293
      previous post link not working.
      SiS - Welcom to Silicon Integrated Systems Corporation.
      • JIMCEE
        • 94
        Hi Steph, can you talk me through it m8. as i am not that up on this ?
          Go to the link given to you by dasteph and download the latest drivers for your graphics card. Install them on your pc and you will not see that mesage anymore. If there is a .exe file in the drivers when you download it, double click it and it will install new drivers for you. If there isn't, Go to control panel\system\device manager\ Look for display adapters, update drivers. browse computer and point to the file and run. This should install drivers for you.
          • JIMCEE
            • 94
            BULLDOG how can i check which graphic card i have m8? sorry to sound a numbnuts but new to all of this, i need it explained in easy terms, cheers
            • dasteph
              • 1293
              if you use device manager and find display adapter double click , then the graphics will then be displayed right click on it for properties, click the properties for a small box to open, once open you will see a tab for drivers from there you can update the drivers.
              • JIMCEE
                • 94
                tried above steph, says cant find a better match ?
                • Patrik1974
                  Hello,
                  im looking for some jtag tools.
                  • JIMCEE
                    • 94
                    SiS 741- driver version SiS driver version 6.14.10.3600. dunno if that helps guys.
                    • dasteph
                      • 1293
                      having looked at the sis website the driver version is lower than the one already installed,it also points out pc builders install there own drivers compatble with your sis graphics and as you have checked the version installed it may be a case of uninstalling the driver then reinstalling it to cure the problem.
                      what you don`t say is what make and model your pc is as the web site of the makers is where you may get your currant version of the driver from.
                      • JIMCEE
                        • 94
                        thanks steph, as i say not all that clever with these things, but the pc was built by a friend who i dont see anymore so looks like im fkd.
                        • dasteph
                          • 1293
                          it is possible overcome your problem, how old is your pc,the reason i ask is because your installed graphics could be onbored graphics which is part of your motherboard. you could install a cheap end graphics card if you have a graphics slot (?10-?30) which would be good enough for serfing the web etc. if you did this you could then disable your present graphics driver, but to do this you need to open your pc and look for a slot which is normally brown in colour (avg) and about 4inches long which is normally near your expansion slots (pci) at the rear of your pc on your motherboard.
