help acer aspire one
  • ray978
    • Aug 2009
    • 586
    please help me friends.
    I aspire one
    mdel zg5
    is discharged the battery is no longer light.
    I would like to do a reset of the bios.
    What should I do about it?
  • Canker_Canison
    • 3904
    Will it turn on with the charger plugged in?
    I take it the battery is not working/charging.
    Canker
    [COLOR=Green]
    • ray978
      • Aug 2009
      • 586
      should not be ..
      as if the bios was dead
        Sounds like the power supply or motherboard then..............
        • ray978
          • Aug 2009
          • 586
          mother board da0zg5mb8f0
          bios 3308
          • Canker_Canison
            • 3904
            Is the charge port loose?
            Common problem on all laptops & netbooks. A damaged charge port will obviously stop it from working once the battery is flat.
            Canker
            [COLOR=Green]
            • ray978
              • Aug 2009
              • 586
              does not appear to be the problem because the battery is charged and the battery is ok
              • mousedeb1017
                • Dec 2011
                we have this with the dell 1520 can anyone help
                • ray978
                  • Aug 2009
                  • 586
                  I do not understand
                  • Canker_Canison
                    • 3904
                    So, does this just fail to do anything or does it fail to post (beep & show the press DEL to enter bios screen)?
                    Canker
                    [COLOR=Green]
                    • ray978
                      • Aug 2009
                      • 586
                      buttons only lights that light up .. the screen does not start
                      • Canker_Canison
                        • 3904
                        How old is it?
                        Has it been used on someones lap, arm of sofa, bed?
                        The last time it worked, was it screaming it's guts out (fan very noisey)?
                        Canker
                        [COLOR=Green]
                        • ray978
                          • Aug 2009
                          • 586
                          Originally posted by Canker_Canison
                          How old is it?
                          fan is noisy ... everything was ok before the battery is discharged ...
                          has about a year old already has broken
                          • ray978
                            • Aug 2009
                            • 586
                            this is my motherboard.
                            I seek a way to reset to see if I can get.
                            friends please .. I ask you if you have a solution to help me
                            • Canker_Canison
                              • 3904
                              Have a read here.
                              I would also repaste the heatsink while you're there.
                              Canker
                              [COLOR=Green]
