Started my PC upa dn get this error that is in the image attached.
I click continue and it comes back.
I click on "details" and it says this.....
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at HP.CUE.Video.PlaybackControl.UpdateProgressBar()
at HP.CUE.Video.PlaybackControl._ProgressTimer_Tick(O bject sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2490
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
hpqimzone
Assembly Version: 3.0.0.0
Win32 Version: 053.000.013.000
CodeBase: file:///C:/Program%20Files/HP/Digital%20Imaging/bin/hpqimzone.exe
hpqiface
Assembly Version: 4.0.0.0
CodeBase: file:///c:/windows/assembly/gac/hpqiface/4.0.0.0__a53cf5803f4c3827/hpqiface.dll
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
hpqcc2
CodeBase: file:///c:/windows/assembly/gac/hpqcc2/3.0.0.0__a53cf5803f4c3827/hpqcc2.dll
hpqutils
CodeBase: file:///c:/windows/assembly/gac/hpqutils/4.0.0.0__a53cf5803f4c3827/hpqutils.dll
hpqfmrsc
CodeBase: file:///c:/windows/assembly/gac/hpqfmrsc/4.0.0.0__a53cf5803f4c3827/hpqfmrsc.dll
hpqtray
CodeBase: file:///c:/windows/assembly/gac/hpqtray/4.0.0.0__a53cf5803f4c3827/hpqtray.dll
hpqovskn
CodeBase: file:///c:/windows/assembly/gac/hpqovskn/3.0.0.0__a53cf5803f4c3827/hpqovskn.dll
hpqimvlt
CodeBase: file:///c:/windows/assembly/gac/hpqimvlt/3.0.0.0__a53cf5803f4c3827/hpqimvlt.dll
hpqimgrc
CodeBase: file:///c:/windows/assembly/gac/hpqimgrc/4.0.0.0__a53cf5803f4c3827/hpqimgrc.dll
hpqntrop
CodeBase: file:///c:/windows/assembly/gac/hpqntrop/4.0.0.0__a53cf5803f4c3827/hpqntrop.dll
Interop.hpqcxm08
Win32 Version: 53.0.13.000
CodeBase: file:///c:/windows/assembly/gac/interop.hpqcxm08/3.0.0.0__a53cf5803f4c3827/interop.hpqcxm08.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
LEAD
Assembly Version: 13.0.0.113
Win32 Version: 13.0.0.113
CodeBase: file:///c:/windows/assembly/gac/lead/13.0.0.113__9cf889f53ea9b907/lead.dll
LEAD.Wrapper
CodeBase: file:///c:/windows/assembly/gac/lead.wrapper/13.0.0.113__9cf889f53ea9b907/lead.wrapper.dll
LEAD.Windows.Forms
CodeBase: file:///c:/windows/assembly/gac/lead.windows.forms/13.0.0.113__9cf889f53ea9b907/lead.windows.forms.dll
LEAD.Drawing
CodeBase: file:///c:/windows/assembly/gac/lead.drawing/13.0.0.113__9cf889f53ea9b907/lead.drawing.dll
interop.hpqimgr
CodeBase: file:///c:/windows/assembly/gac/interop.hpqimgr/3.0.0.0__a53cf5803f4c3827/interop.hpqimgr.dll
hpqthumb
CodeBase: file:///c:/windows/assembly/gac/hpqthumb/3.0.0.0__a53cf5803f4c3827/hpqthumb.dll
hpqasset
CodeBase: file:///c:/windows/assembly/gac/hpqasset/4.0.0.0__a53cf5803f4c3827/hpqasset.dll
hpqmirsc
CodeBase: file:///C:/Program%20Files/HP/Digital%20Imaging/bin/hpqmirsc.DLL
hpqedit
CodeBase: file:///c:/windows/assembly/gac/hpqedit/3.0.0.0__a53cf5803f4c3827/hpqedit.dll
hpqvideo
CodeBase: file:///c:/windows/assembly/gac/hpqvideo/3.0.0.0__a53cf5803f4c3827/hpqvideo.dll
LEAD.Windows.Forms.DrawingContainer
CodeBase: file:///c:/windows/assembly/gac/lead.windows.forms.drawingcontainer/13.0.0.113__9cf889f53ea9b907/lead.windows.forms.drawingcontainer.dll
hpqmdmr
CodeBase: file:///c:/windows/assembly/gac/hpqmdmr/4.0.0.0__a53cf5803f4c3827/hpqmdmr.dll
LEAD.Drawing.Imaging.ImageProcessing
CodeBase: file:///c:/windows/assembly/gac/lead.drawing.imaging.imageprocessing/13.0.0.113__9cf889f53ea9b907/lead.drawing.imaging.imageprocessing.dll
hpqimlib
CodeBase: file:///c:/windows/assembly/gac/hpqimlib/3.0.0.0__a53cf5803f4c3827/hpqimlib.dll
hpqglutl
CodeBase: file:///c:/windows/assembly/gac/hpqglutl/4.0.0.0__a53cf5803f4c3827/hpqglutl.dll
Interop.hpqvideo
CodeBase: file:///c:/windows/assembly/gac/interop.hpqvideo/3.0.0.0__a53cf5803f4c3827/interop.hpqvideo.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
How can i fix this? As it won't close, and it's at the front of my PC all the time
mscorlib
hpqimzone
hpqiface
System.Drawing
System
hpqcc2
hpqutils
hpqfmrsc
hpqtray
hpqovskn
hpqimvlt
hpqimgrc
hpqntrop
Interop.hpqcxm08
System.Xml
LEAD
LEAD.Wrapper
LEAD.Windows.Forms
LEAD.Drawing
interop.hpqimgr
hpqthumb
hpqasset
hpqmirsc
hpqedit
hpqvideo
hpqmdmr
hpqimlib
hpqglutl
Interop.hpqvideo
enabled.
For example:
<configuration>
</configuration>
