Dell Latitude E5410 Admin Password help?
  • CBR1000RRider
    • Dec 2011
    • 4
    I bought a Dell Latitude E5410 off of Craigslist and it had an Admin Password set.
    I was wanting to update my BIOS and then Re-Install windows.
    But when I tried flashing the BIOS the "System Admin Password" popped up.
    I contacted the seller and he wasn't aware of a system password, apparently this is a third hand laptop.
    So would anyone know the Backdoor/Root password?
    2N836N1-2A7B
  • CBR1000RRider
    • Dec 2011
    • 4
    I tried the Dell 2A7B keygen off of Dogbert's Blog and had no success with the one it gave me.
    Said master code was nnnnnnbn
    Revision A04 Bios currently
    • smoggy
      • Apr 2009
      • 12772
      master password is 9325mzudPuk1Id4l note changes from lower to upper case
      • CBR1000RRider
        • Dec 2011
        • 4
        Didnt work.
        Thank you for trying though.
        See if i can find a recovery disk and restore it to factory settings.
        • kam
          • Sep 2009
          • 54
          Digital Kaos - Downloads - Dell password generator
          • LordOfRings
            • Jan 2012
            Hello How can I find a dell e6410 password for HDD
            thank you
            • WhiteRabbit
              • Feb 2012
              Thanks kam, Hope this one works...
              • dodgeit
                • Apr 2012
                Does it work?
                • ROBERTO TANHOLI
                  • Jun 2012
                  ola sera que esse progama funciona em um dell 5410
                  • Jootje00
                    • Aug 2012
                    Hallo,
                    Need also MP for latitude 1KNJ4S1-1D3B
                    Please help.
                    • mrouzo
                      • 16
                      When the master password doesn't work you can always do it the old fashioned way by resetting/disconnecting the bios memory.
                      Go to this page and scroll down to "How do you manually Unlock and reset the password from your Dell latitude Laptop?"
                      DELL LATITUDE e5410 BIOS PASSWORD, Unlock & Reset your Laptop in minutes, Aug 03 2012
                      • dongsdongsdongs
                        • Aug 2012
                        • 4
                        Founds this thread via google. Will be downloading the tool as recommended by kam as soon as the forum grants access to downloads. I'll let you all know if this works for me. I'm trying to remove an administrative bios password from a Latitude E5410. Also, bookmarked the site. I might lurk on and off for the next few days.
                        EDIT: I consistently get the "incorrect password entered" error with the generated code. I've tried both the 7 character serial number, as well as the 7+4 character number (in format xxxxxxx-xxxx) and neither seems to work. On an only slightly related note, the .rar'd executable, dell.exe, works great in Wine on linux (as I don't have Windows on this particular system) Does anyone know if there is an updated version of this program? I think it's possible that Dell updated their master codes after this software was released (or that it just doesn't work). Thanks!
                        EDIT2: It seems like the software is just not compatible with the newer computer. I locked a Latitude D610 with a test password, and it broke it flawlessly.
                        • dongsdongsdongs
                          • Aug 2012
                          • 4
                          Bump. I used the above tool to successfully remove the password from a Dell Inspiron 600m.
                          I must reiterate, as I stated in my previous post, that it did not work on the newer Latitude E5410. Does anyone have an updated version of the dell.exe program that will work on newer Dells?
                          I think it's possible that Dell updated their master codes after this software was released (or that it just doesn't work (on newer Dells))
                          • smoggy
                            • Apr 2009
                            • 12772
                            suffix 1D3B and second generation 595B are the latest and at present they can only be done by Dell and paid service websites
                            • thesparkly1
                              • Feb 2012
                              Presumably you could just clear the CMOS by removing and then reinstalling the CMOS battery. This might be a simple way of fixing the problem
