Fan broke?
  • lee_hdi
    • 928
    Fan broke?
    Is the fan at the back of the tower supposed to be on when the PC is running?
    The one on the processor is working, and just thought that one was supposed to come on to blow the hot air out
    Don't let failure go to your heart, don't let success go to your head.
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    yes it should be working.. cheap and easy enough to replace tho.. should be able to have between an 80-100mm fan fitted
    • lee_hdi
      • 928
      They just a bog standard fan in all PCs?
      If so I'll just take one out of a old pc.
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        yep molex connector
        • cactikid
          • 12017
          maybe not as i had my pc open and fan has not turned from day 1 as in cables tied together,go into your settings and check fan settings maybe the second one does not cut in until you start clocking?
          • alistairlee
            • Feb 2010
            • 15
            Check that the fan is getting 12v supply and that its directly connected to the power connector (looks like it), if so it should spin, replacing like with like from an old pc will be ok, just check airflow direction.
            Al
            • MrWho
              • 417
              They are not critical ..but you can replace it they are cheap .. if by any chance your fan connection is dead get a one for molex ... and not feeded from motherboard ,,,
              If you will have any questions let me know ...
              Please click >>>> THANKS >>> If I helped you.
