desktop icons
  • magic
    • 20
    desktop icons
    for some unknown reason a small square has appeared on top of my desktop icons how do i get rid of them im using win7 ta magic
  • andy211081
    • 575
    get a print screen of your desktop and post here buddy
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
    • magic
      • 20
      hi andy how do i go about getting a screen print sorry for my ignorance , magic
      • rg66
        • Dec 2011
        • 133
        Press the print screen button on your keyboard. Open a program such as MS paint and paste it in. Save it as a jpeg.
        • Reapers
          • 242
          try this
          it should sort everything for you
          its a exe just download and run
          • magic
            • 20
            thanks but dident work
            magic
            • andy211081
              • 575
              when you say squares are they like the shortcut squares?
              • magic
                • 20
                ive managed to get a screenshot how do i paste it and send it to you ta magic
                • Jaffa
                  • 1612
                  Click post reply, page down until you see manage attachments, click that then click browse and go to where you have the image, after upload click close window and submit reply.
                  • magic
                    • 20
                    screenshot
                    hope it works magic
                    • Reapers
                      • 242
                      from what it looks like the icons have lost the association with their programs or registry
                      have you used registry cleaner software recently
                      have you tried resetting your icon cache?
                      if not
                      heres the fix it link
                      download
                      run it as admin
                      then when you download your package
                      and you get options make sure you tick
                      icons and customization
                      other or i dont know
                      select next
                      and then let it do the work.
                      also if you are using registry cleaning software some are too intensive in their scans and can remove the wrong thing.
                      use ccleaner
                      its the number 1 at the moment
                      and proberly the most safe one around.
                      CCleaner - Optimization and Cleaning - Free Download
                      hope it helps
                      • johnsayre
                        • Jan 2012
                        Have you tried changing your background?
                        • magic
                          • 20
                          ive tried all your recomendations inclulding crapcleaner ive changed the background and run microsoft fix still the same icon promblem thanks for your help folks, i think ill have to do a re install what do you think
                          • rg66
                            • Dec 2011
                            • 133
                            Do the shortcuts still open the programs? If not, right click one and click properties and check that the "target" path is correct (see my attached screen shot).
                            If they do open then again right click one and click properties. Click on "change icon", the path to the icon should be the same as the target path and it should show one or more icons to choose from. If not just change to the right path and choose an icon.
                            • magic
                              • 20
                              i tryed that rg66 but still no diffrence ta magic
