Computer randomly switching off and hard to reboot?
  • inorange
    • Oct 2011
    • 41
    My computer keeps randomly switching off. Once it has switched off, its very hard to get it to turn back on again. However, when it is fully booted it can stay on for several hours.
    Is it most likely the fan/overheating, power supply, software issue, or something else?
    Its a Dell 530s desktop which is 3 years old. There was a problem with these types of Dell in that they had very noisy fans and needed a BIOS update. Once I did this the fan improved but often the fan can be quite noisy. There have been times when I've noticed the PC has got hot but since I've had this problem it doesn't seem particularly hot.
    When the computer turns off it says 'Auto detect, entering power save'. I went into the BIOS and switched the selection to automatically turn the computer on after a power failure to 'ON'. However, I regret this as maybe I need to let the PC cool down. Before doing this though, sometimes it would automatically try and turn itself on again a few seconds after switching off anyway.
    Since I've changed the BIOS so that it automatically switches on after 'power failure', the PC is continually trying to switch on, but there seem to be breaks in doing so.Today its turned on so that you can see the Dell Sign and the 'press f2 or f12' in the bottom right hand corner and then usually switches off after this. Straight away it will turn on again and this repeats a few times. Then there's a 5 minute or so gap, then the cycle repeats,Tonight I managed to get to the Welcome screen for windows but then it switched off again.
    I have my PC plugged into a multi-socket adapter. My speakers are plugged into the same adapter and they have a green on light which remains on so its not some strange problem with the electricity in my house. Having said that I'm writing this on a plugged in macbook pro laptop and the power supply feels very hot, is this normal?
    I'm a bit concerned about taking my computer to a shop as they could charge me anything they like and the problem might not even get resolved.
    I'd be grateful if someone could give me their opinion of what the problem most likely is and what I should do. I've never opened a computer before but I'd be willing to give it a go if it was simple enough.
    Thanks.
  • willywonker2010
    • Mar 2010
    • 449
    could be power supply buddy
    u need to check temps ov motherboard and parts
    • R_J
      • 492
      I would suspect the power supply, easy enough to change. You could also disconnect the hard drive and cd/dvd drive power connectors, if the computer stays on with the reduced load it would mean power supply is bad.
      On some dell and emachines when first turned on the cpu fan runs at full speed until the bios takes control of the speed and slows it down. When computer is operating the bios will control the speed according to the internal temp. of the cpu.
      here is a link to the manual http://support.dell.com/support/edoc.../PDF/om_en.pdf
      • MrWho
        • 417
        If your fan is speeding up then reset that means that your system is overheating ...
        Vacumm inside be carefull .. maybe remove heat sink and new quality paste.
        Please click >>>> THANKS >>> If I helped you.
