whats wrong with my wifi ? i can connect ok with ethernet cable but wire-less gives me limited connectivity i have updated driver un/reinstalled device reset router been on the phone to sky for ages to no avail im sure router is ok coz i have another laptop and pc plus xbox and printer all working fine is the wifi goosed ? the card is atheros ar5007eg, running on vista home other lappy win7 pc is xp..cheers
limited connection
Tags: None
Does your other laptop connect through wireless? If so does it also have limited connectivity? If it does as well it sounds like a router issue, if not then a wireless card issue with the laptop.
If it's the router, you could look for a firmware update and see if that helps.
I had a linksys router that developed this problem over time. It was a hardware issue, and the fix was to buy a new one.Last edited by rg66; 27 January, 2012, 06:30.sigpic
