lost taskbar desktop icons, need help.
  • ranger
    • 178
    hi everybody, i have a dell labtop xp, i have lost all icons/taskbarr / start, i just have wallpaper background showing, i have tryed Task manager, typeing in (explorer .exe) amd i tryed system restore , but still no taskbar or icons or start, any ideas welcome, thanks,
  • hoggy952
    • 1229
    A program called explorer.exe controls the display of your taskbar and desktop icons. If for some reason it goes missing (you may have killed it using Task Manager, for example, or something more sinister like a virus has deleted it from your processes), then try this first:
    1. Open Task Manager (press Ctrl+Alt+Del, then click Task Manager).
    2. On the Applications tab, click New Task at the bottom right of the window.
    3. Type explorer.exe, then click OK.
    If nothing sinister caused it to disappear, it should all come back as it was and you can stop panicking, breathe a sigh of relief, and continue working.
    If that does not work, then try this:
    2. Go to the Processes tab.
    3. Click on the Image Name column header to sort the list alphabetically.
    4. Find all explorer.exe processes - select each, then click End Process for each one.
    5. On the Applications tab, click New Task at the bottom right of the window.
    6. Type explorer.exe, then click OK.
    • ranger
      • 178
      lost taskbar/icons
      hi , i have tryed that today , but in image name , i cant find explorer.exe) its not on the list? thanks again,,
      • oscar0627
        • Dec 2010
        • 112
        What happens when you go into Safe Mode? How about Safe Mode with Command Prompt?
        • ranger
          • 178
          it wont do anything in safe mode, it will not start up in safe mode. it just gives a black screen with the word .. safe mode in the screen, but it will not boot up in any of the safe modes,, thanks
          • Reapers
            • 242
            might be a corrupt profile
            press ctrl alt del file-run- start explorer.exe
            or
            reset your desktop
            also use your security softwares to check any problems like viruses and other threats
            • Bann32
              • Oct 2011
              • 518
              Do you have a system restore?
              If so try to revert back to that, then run a AV check and on top of that id...
              Run command prompt as administrator Start -> Accessories, right click command prompt and run as administrator. Type SFC /scannow then press enter
              • vicxtm
                • Jan 2012
                first one worked for me.
