Boot loop win xp
  • cablefreejunkie
    • 1717
    Boot loop win xp
    Helllo peeps
    Well as the title says im stuck with my laptop trying to boot up
    Basically it boots up then i get a screen saying iwindows did not start correctly with options to fire up in safe mode etc etc
    If i select any option it then goes blank and a blue screen appears saying theres a soft ware or hardware
    Problem been detected
    I cant read it all as the screen goes blank again and then back to the previous screen
    Cant figure it out
    Any help much appreciated
    Im on xp hedition 32 bit sp3
    The control of information is the consolidation of power
    ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
    IF I HELPED HIT THE THANKS BUTTON
    Have you tried booting from the Windows cdrom and choosing Repair?
    • cablefreejunkie
      • 1717
      I dont have it
      • cablefreejunkie
        • 1717
        I have a product recovery cd
        Would that be of any use to me ?
        • Bann32
          • Oct 2011
          • 518
          Yes - But do you have anything important on the pc?
          • Cod3waX
            • 1011
            do a quick hardware check first m8 could be ya hdd has come loose or a dodgy ram stick
            • cablefreejunkie
              • 1717
              I do have important stuff i need to keep
              • Bann32
                • Oct 2011
                • 518
                id be careful using a product recovery cd, it may just restore everything to default and wipe the rest, what make is the laptop?
                • cablefreejunkie
                  • 1717
                  Ttoshibe sattelitte
                  Mate at work is going to sort me out a xp boot cd
                  Will give that a go and see if i can get it started
                  If not its to the shop to try and get the data back from the hdd
                  Fingers crossed
                    my tower is experiencing the same prob ever since i took the sp3 update.
                    it says i have a hardware fault but lets me proceed by pressing f1
                    not sure if this helps m8
                    • haribo
                      • 157
                      Recovery CD's will generally wipe your C: partition clean,
                      the only expepetions are Sony Vaio recovery centre, and HP recovery centre, both which give you solution to backup your files before recoving the disk from the recovery paritition.
                      best idea, download Hirens boot disk,, boot to mini-xp,put your files onto usb drive, and then use windows disk or recovery partition to recover your windows, then recovery your data form your usb.
                      cheers
                      • cablefreejunkie
                        • 1717
                        cheers
                        Ok
                        So i dl hirens
                        Whats boot to mini xp ? Im a novice by the way
                        Also i have quite a lot of jpegs and docs i need to save
                        I wont get them all on a usb will i ?
                        Also i dont have 2 partitions just one 70 gb
                        Hope this makes sense
                        • haribo
                          • 157
                          Originally posted by cablefreejunkie
                          Ok
                          So i dl hirens
                          on the hirens disk theres a utility called mini-xp..
                          It basically boots your pc into a mini-xp, and mounts your internal drives,( boots from the CD and creats a RAM disk to boot from ),, so you get a usuable xp and you can see your drives in my computer.
                          usb drive i dont know, it depends, you can defo get drive's larger than 70gb though so even if you wanted backup your full drive, ( which you dont, you only want the user folder with the pics and docs, )
                          were talking an external drive not a usb pen or flash drive,
                          you can use a pen drive of flash drive if your docs are under the size of the drive, which you can get a 8gb one cheap as chips.
                          if your machine only has 1 partition 70gb, using a recovery disk would defo wipe out the entire drive. but if you have booted into mini-xp and saved all your stuff first, it doesnt really matter.
                          • haribo
                            • 157
                            oh, have your usb drive plugged into computer BEFORE you boot the mini-xp, or it might not see it in my computer once you boot into the mni-xp
                            • cablefreejunkie
                              • 1717
                              Excellent info haribo
                              Makes sense now
                              I will forget the tosh recovery cd and dl hirens and give that a shot
                              Cheers
