Boot loop win xp
  • cablefreejunkie
    • 1717
    #76
    i had 2 2gb sticks and the lappy would not work correctly,,then tried one and it was fine,,so i sent the other one back to crucial for a refund,,they even scanned the lappy through there site beforehand to advise what i could and couldnt have so i dont need another ram stick as it wont work
    need the 500gb hdd though,,
    The control of information is the consolidation of power
    ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
    IF I HELPED HIT THE THANKS BUTTON
    • cunny
      • 4915
      #77
      Post make and model of laptop mate. If there is 2 dimm slots on board then both can be populated. Only thing is how much and speed the board can handle.
      There could even been a bios update to allow more ram to be added.
      Sent from my GT-I9000 using Tapatalk
      • cablefreejunkie
        • 1717
        #78
        toshiba satellite p100-227
        there are two slots for RAM,forgot to add in previous post that i have the 2gb stick alongside the 512 so both slots are populated
        • haribo
          • 157
          #79
          That p100 model *should* take the 4gb,,,
          thats its Max,, or it should be, are you sure both sticks were ok (2gb ones)?
          on your ram stick look for like someone mentioned pc-6400 800MHZ,,,,
          or 5300 and 600MHZ?
          check both sticks are same.
          as for drive, been said already, get a 500gb
          • Cod3waX
            • 1011
            #80
            i like the looks of this 1
            Seagate Momentus XT 500GB 2.5" SATA Internal Hard Drive (ST95005620AS) - www.misco.co.uk
            i think cruical ****ed up with the ram 1 stick may have been broken did u test this by changing them over n booting to windows b4 u decieded that it couldnt take it? becuase if it couldnt ur 512 that u got in there atm shouldnt work either
            how much laptop ram has ur son got in his?? if he has 4GB then pull this outta his n put intoo urs making sure its DDR2 or PC2
            if not n he only has 1 2GB stick make sure again its DDR2 and see if it matches ur stick PC2-5300 EXample
            if it is the same slot it in n see if it boots/sees it in windows
            • genakip
              • Mar 2012
              Good team!
              It is very actual team!
              I dont have it
